Cheap Place to get the Accord Antenna
Old Oct 31, 2002 | 09:18 AM
99_IntegR's Avatar
Default Cheap Place to get the Accord Antenna
The antenna on my 95 Accord snapped off and I'm looking to replace it, but the dealership wants an arm and a leg for a replacement one.
Does anyone know a place online or located in So. Cal where I can pick up a motorized replacement antenna for cheap?
Thanks
Old Oct 31, 2002 | 10:02 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Cheap Place to get the Accord Antenna (99_IntegR)
I picked mine up on e-bay last spring because the ice frooze it and then killed the motor. I got mine for $40 plus like $5 shipping. When I was looking for one I remember there were a lot up for auction so you should be able to find one. Oh yeah, it was new in the box (not used) with instructions and a warranty. If it's just a mast your looking for I think they were going for like $20-25 plus shipping on e-bay.
Old Oct 31, 2002 | 11:26 AM
mrnicolas's Avatar
Default Re: Cheap Place to get the Accord Antenna (TouringAccord)
Mine broke, so I shaved it off.
Old Oct 31, 2002 | 11:28 AM
Accord94DX's Avatar
you can get a manual replacement from the dealer for ~$35.
Old Oct 31, 2002 | 08:11 PM
Mr Ben's Avatar
Default Re: Cheap Place to get the Accord Antenna (Accord94DX)
Good Guys or Circuit City will have replacements, I think they are about $60.
Old Oct 31, 2002 | 08:32 PM
droccadnoh's Avatar
My mechanic is usually able to get good deals. I don't know how much but you can give him a try. 714-952-9403. His name is Nho (pronounced 'know').
Old Oct 31, 2002 | 08:58 PM
EndlEEsss's Avatar
Default Re: Cheap Place to get the Accord Antenna (droccadnoh)
wow, wait, i dont think u need to replace the whole motor.
You probably only need the antenna mass. $10 on ebay
its easy to replace your selft.
all i did was turn on the radio, yank the old one out with my bare hands
and then feed the new one with the tracks in it, and turn of the stereo.
then shove the rest of the antenna into the body.
i did this on my gf 94, im glad i have a 96
Old Nov 1, 2002 | 03:12 AM
Hippie's Avatar
I have two 4th Gen Accord EX's with the optional (or dealer installed ? Every EX around here has it......) rear wing. The wing catches the antenna when you close the trunk. The guy I bought my '91 from had replaced 3. A guy at work has the same problem with his '93. Found a black "rubberized" antenna about 10" tall at Auto Zone for $9.99 that looks pretty good and has good reception. The wing just touches the tip when you close the trunk and since it flexes it doesn't hurt it. Power antennas are a pain in the *** anyway.
Old Nov 1, 2002 | 05:10 AM
Stew Pidasso's Avatar
Default Re: Cheap Place to get the Accord Antenna (Hippie)
Antennas are just ugly anyway. I love the 94 EX antenna is integrated into the back window.
Old Nov 1, 2002 | 05:18 AM
mailforjon's Avatar
just a thought: if you turn OFF the radio before opening or closing the trunk, you shouldnt have a problem breaking them off.
Old Nov 1, 2002 | 07:23 AM
2000Accord5sp's Avatar
Default Re: Cheap Place to get the Accord Antenna (Stew Pidasso)
I have a 94 EX and the antenna isn't integrated in the window...why's that?
Old Nov 1, 2002 | 07:40 AM
Hippie's Avatar
Default Re: Cheap Place to get the Accord Antenna (mailforjon)
I didn't have a problem, the guys that owned the cars before me did, I'm just too f*@%ing cheap to shell out for a power antenna. They are a waste of money as fas I'm concerned.
Old Nov 1, 2002 | 07:42 AM
EndlEEsss's Avatar
Default Re: Cheap Place to get the Accord Antenna (2000Accord5sp)
cause only the 96 and 97 have integrated antenna, not the 94 or 95
Old Nov 1, 2002 | 07:58 AM
Accord94DX's Avatar
Default Re: Cheap Place to get the Accord Antenna (TweakMeUp)
some 95s had them.
Old Nov 1, 2002 | 08:01 AM
H-T Order of Merit
some 95s had them.
Which models?
Old Nov 1, 2002 | 08:26 AM
I have a 94 EX Coupe with leather and I most certainly do have an antenna integrated into my back window. I have a friend with a 97 EX with a regular antenna.
Old Nov 1, 2002 | 08:31 AM
H-T Order of Merit
So is it only 94 EX then cause I have a 95 EX with a power antenna.
Old Nov 1, 2002 | 08:35 AM
Hmm I cant imagine why Honda would only do this on certain models. This lack of an external antenna makes for cleaner and more aerodymic bodylines. I wonder if they did it to experiment or something. Has anyone ever heard if these in-window antennas have problems or worse reception? I know some domestics put them in the windshield a while back but had problems if the windshield cracked or something.
Old Nov 1, 2002 | 08:40 AM
Accord94DX's Avatar
I've never noticed a difference in reception with the in-glass vs. retractable antennas, the nice thing about the in window ones is that you don't have to worry about breaking them when you run the customers car through the car wash at work......dumb n00b runners always did that **** at my work
Old Nov 1, 2002 | 08:43 AM
H-T Order of Merit
So if someone wanted to shave their antenna they could get the rear window with the integrated antenna. Where would you get one from?
Old Nov 1, 2002 | 08:45 AM
Accord94DX's Avatar
i don't think it would be worth the cost. Honda would carry it for sure, im not positive if ABRA or other aftermarket glass replacement services *** around with that stuff.
Old Nov 1, 2002 | 08:55 AM
H-T Order of Merit
How much do you think one would cost? Also, how hard would it be to hook one up?
Old Nov 1, 2002 | 08:58 AM
Accord94DX's Avatar
Probably close to $450-$500 for the rear windshield and you would have to reroute the antenna wire to the C pillar.
Old Nov 1, 2002 | 09:02 AM
H-T Order of Merit
Ouch....ok, thanks.
Old Nov 1, 2002 | 11:15 AM
EndlEEsss's Avatar
well you can shave the antenna and get a cheap window antenna kit for about $50, also you can just use a regular antenna and mount it somewhere in the car, i did that on my crx, i put it in the trunk and it worked fine.
