B16 CRX peeps (help)
Old Oct 31, 2002 | 09:00 AM
REDBARON's Avatar
Default B16 CRX peeps (help)
Hey guys. I'm needing some help with a couple of my problems. I have 91 CRX HF with a B16. Now here's my problem.
While I'm crusing my engine kinda surges. Not really bad, but enough for me to feel it. I also notice on my A/F gauge that it goes really lean, then it will go rich, and I can feel the car jerk slightly. It won't do it when I'm at FOT, and I don't have any CEL codes.
What could this be????
Old Oct 31, 2002 | 09:09 AM
EL Vap133's Avatar
Default Re: B16 CRX peeps (REDBARON)
I think it could be your TPS.....
Old Oct 31, 2002 | 09:14 AM
ngkplugs's Avatar
Default Re: B16 CRX peeps (Vap133)
i say it is deff a senser try the tps
Old Oct 31, 2002 | 09:21 AM
Rob!'s Avatar
Old Oct 31, 2002 | 10:42 AM
red civic standard's Avatar
Default Re: B16 CRX peeps (RaceFacer)
you are having o2 sensor issues. You have one of two problems.
1) your second o2 sensor wire is not making contact at the ecu. jam it in there.
2) your o2 sensors are reversed. switch them (no don't take them out and switch them...just swap the two wires...it is easiest at the ecu.
try these things....if its not these then i don't know.
Old Oct 31, 2002 | 11:03 AM
REDBARON's Avatar
Default Re: B16 CRX peeps (red civic standard)
Thanks for the help guys. I'll have to check these things out.
Old Oct 31, 2002 | 11:14 AM
kHoA DoGG's Avatar
QUOTE]I think it could be your TPS.....[/QUOTE]
wat's the tps sensor? where is it located?[
Old Oct 31, 2002 | 11:24 AM
raene's Avatar
Default Re: B16 CRX peeps (sNoOzin' EF8)
On the back of your throttle body, connected to the throttle cable. It's the 3-wire sensor that tells the ECU how much gas you're giving it (Throttle Position Sensor)
Old Oct 31, 2002 | 01:36 PM
Phatwhippin_CRX's Avatar
Default Re: B16 CRX peeps (raene)
you'd be throwing a code 7 if your TPS was fucked.....
Old Oct 31, 2002 | 02:13 PM
rice_classic's Avatar
Default Re: B16 CRX peeps (Phatwhippin_CRX)
It's not your TPS.
You're O2's are BACKWARDS. Just take wires that come from the sensors off the manifold and cut and splice them as to switch the signals.. If you don't understand IM me. You should understand if you got this far by yourself
Old Oct 31, 2002 | 02:21 PM
forensics.'s Avatar
Default Re: B16 CRX peeps (rice_classic)
if its obd0, which it prolly is, its NOT the 02s
Old Oct 31, 2002 | 02:59 PM
Danbu$'s Avatar
Default Re: B16 CRX peeps (strictlyhondas)
what exactly rules the 02 sensors out ?
if he has the two sensor wires connected to one sensor, or the sensors reversed that could cause the engine to run incredibly rich or incredibly lean causing a bogging\hesitation.
i say check the o2 sensors
Old Oct 31, 2002 | 05:26 PM
REDBARON's Avatar
Default Re: B16 CRX peeps (Danbu$)
Ok I will check the O2 sensors and make sure they are connect good on the ecu, and also reverse them to see how it acts.
Old Oct 31, 2002 | 06:17 PM
MADEINIRAQ's Avatar
it is the o2 sensors.. guaranteed.
switch them on the ecu Pins c8 and c16
no cutting and splicing needed.
good luck.
Old Oct 31, 2002 | 06:18 PM
MADEINIRAQ's Avatar
you sir are a dumbass..
Old Nov 1, 2002 | 06:25 AM
REDBARON's Avatar
Default Re: B16 CRX peeps (madeiniraq)
Hey guys, how do I move the pins on the ECU? Don't you need a special tool for that?
Thanks.
Old Nov 1, 2002 | 09:07 AM
i just cut the wires about 2 inches from the plug that goes into the ecu and then spliced em. just make sure you cover them up good with electrical tape.
Old Nov 1, 2002 | 10:30 PM
Sgt_Ox's Avatar
WTF????? What is then? If your so sure! I'm going with the rest of the general public O2 sensors are either reversed or you have them both spliced into only 1 terminal. People need to realize that most of their 1st gen b16 hesitation problems are solved by correcting installation (human) error.
Old Nov 2, 2002 | 10:04 AM
REDBARON's Avatar
Default Re: B16 CRX peeps (MrDoHc2)
Ok guys, how do I determine which is the primary sensor and the secondary one??
I see them both on the exhaust manifold, but which is which??
Old Nov 2, 2002 | 12:55 PM
MADEINIRAQ's Avatar
to remove the pins.. take the C connector off the ecu.. insert a needle in the hole between the wires.. on the opposite side of the wires
Hold the connector so you look straight at it with the wires on the other side.. and you will see 2 rows of holes where the pins are and the a row of smaller holes between them
insert a pin in the small hole, pointing it slightly towards the pin you wish to remove.. do this while pulling the wire you want to remove. should come out really easy, if not keep pokin around.. you will get it
Old Nov 2, 2002 | 01:24 PM
REDBARON's Avatar
You guys were right!!!
The O2 sensors were backwards. I re-wired them and now it runs great. My A/F gauge even works better because it's reading the Primary sensor and not the secondary like I had it before.
Thanks for all the help!!
Old Nov 3, 2002 | 12:35 AM
Danbu$'s Avatar
Good stuff
let us know if your gas mileage imporves any
Old Nov 3, 2002 | 01:51 AM
Alright.... Somebody call Betty Ford...
The first step is to admit that you HAVE a problem
If it's obd0 LIKE MOST SWAPS OF THIS TYPE....... Then IT'S MOST LIKELY THE O2'S!!
Old Nov 3, 2002 | 10:32 AM
Danbu$'s Avatar
"Alright.... Somebody call Betty Ford...
If it's obd0 LIKE MOST SWAPS OF THIS TYPE....... Then IT'S MOST LIKELY THE O2'S!! "
LOL. gotta love it when rookies join the conversation
Old Nov 3, 2002 | 12:06 PM
kHoA DoGG's Avatar
do you have any pics of what to splice? i already used the carb cleaner and it didn't work, i only see one o2 sensor on my car and it's on the bottom half of the dc headers. pics would help alot! i gotta get my fix it ticket fixed and surging bet. 1500rpms and 3500rpms in front of a cop isn't good.
