retrofit options 95 lude
Old Jul 22, 2014 | 04:39 PM
bdmlilburn's Avatar
Default retrofit options 95 lude
Hello purchasing a 95 honda prelude si tomorrow. H23 vtec already installed woooo!
Ok so first I want to do a retrofit. I want opinions on stock and/oor jdm housings. I know morimoto mini h1 projectors will fit. I fit them in my cb7 with e46 replica shroud no problem. What other possibly better performing projectors will fit into either of these housings?
Slightly off topic but fog lights. Will jdm fog lights fit into the usdm bumper as well as oem usdm fog lights will? Only asking due to different pricing I'm finding online. Thanks in advance
Old Jul 22, 2014 | 05:16 PM
snobordboy's Avatar
Moderator
Default Re: retrofit options 95 lude
I used Morimoto D2s in my JDM lights, and I think they are great. I prefer the one piece look of the jdm lights personally, and most colors look better with the black, but some cars can pull off the chrome housings well.
jdm and usdm, the oem fogs were the same. Just much more common in the jdm market, and the jdm are usually yellow, while usdm were clear.
Old Jul 22, 2014 | 05:23 PM
bdmlilburn's Avatar
Ah morimoto ds2? What's the difference in the ds2 and the h1? I noticed the ds2 projectors are more square while the h1s are circular. The ds2 also cost more. But money is not a concern to me. Do the ds2 hook up similar? When I retrofitted my mini h1s it was super easy. The threaded end of the projector fit right through the oem headlight hole and had a circular screw to hold it on.
Old Jul 23, 2014 | 12:39 PM
snobordboy's Avatar
Moderator
I bought mine when they were still the round ones, and the big difference is is using an actual D2S bulb instead of a re-based bulb. Otherwise the instal was pretty much the same, but the wiring from the ballast to bulb has a single connector instead of the 2 like most other hid rebased bulbs use.
crx_si-r
49
Jun 15, 2008 11:43 AM
jdmracer12
Honda Civic (2001 - 2005)
Aug 26, 2007 02:41 AM
GearDownCRX
16
Jun 8, 2005 05:20 PM
waysian asian
May 17, 2005 10:57 PM
Kool Blue Lude
Nov 14, 2003 02:36 PM
