Side blinkers not working, but bumper do work.
I changed out the switch on the column with two other switches then swapped out two different blinker relays. I put a voltmeter to the sockets and on the socket that works, on the bumper, it reads 3 point something volts. The side blinker has .4 volts. The bulbs are good.
Any suggestions?
1990 Honda Accord Lx
Any suggestions?
corroded wiring most likely. 3.xx to 0.4 is signficant. download a Factory Service Manual or hayes and learn to read wiring diagrams. or just pay someone to repair the wiring
I did a continuity test on the green and white wire just to see if there was a connection with the wire. I also got another Integrated Control Unit (ICU) to exchange. The voltmeter said there was continuity and the ICU didn't change anything. Took a screenshot of what I'm using
elmogs
Jun 29, 2009 12:57 PM
Jay J
Apr 15, 2006 06:40 AM
eghatchattax822
Oct 27, 2005 08:43 AM
