B16B Fully Built EG Hatch
Old Jul 22, 2014 | 08:00 AM
Vinnie909LSVTEC's Avatar
Default B16B Fully Built EG Hatch
Hello,
Well the time has come for me to start my build, here is a lil run down of whats going in it and my plans. Lets start by saying Laskey Racing is doing the build for me, just took him all the parts and block/head to him yesterday.
Spec.
B16B CTR block
Benson Sleeves
GSR Crank
OEM CTR Girdle
OEM Water pump
OEM oil pump
Skunk2 GSR Rods H beam
Wiseco 84mm High Compression Pistons
ARP head studs
B16a Head
Port Flow ported/polish ect.
Supertech Valves I/E
Supertech Dual valve springs
Skunk2 Pro series Stage 2 cams
Blox Intake Mani
Blox billet 68mm TB
BDL cam gears
B16 Hydro Trans Built by Synchrotech
MFactory LSD
I'm still on the hunt for a good Header, cant make up my mind yet. Also on the hunt for a better Intake Mani. So any ideas on something good with a lot of flow feel free to let me know! Also any comments or ideas about the build shot them my way.
here are a couple of pictures
Here is how the car sits now, ls/vtec turbo 272whp @ 10psi
I'll post more photos as soon as they up load.
Old Jul 22, 2014 | 08:03 AM
Default Re: B16B Fully Built EG Hatch
The stock sleeve that was cracked
Old Jul 22, 2014 | 08:28 AM
Acu's Avatar
Acu
Keep us posted!
Old Jul 22, 2014 | 08:50 AM
F22Master's Avatar
Why use gsr internals in a ctr block? Is there any benifit to this?
Old Jul 22, 2014 | 09:13 AM
So it's basically a GSR block and stroke now, a stock b16b shares the same deck height as a GSR, ITR but uses a different crank and rod stroke to make it a 1.6L
A B16B block is a GSR, ITR block but with B16B stamp on the front.
Old Jul 22, 2014 | 07:18 PM
whitesihatch's Avatar
^^yep.
This setup screams for a bigger throttle body.
Old Jul 22, 2014 | 07:57 PM
^Yes I know that! and TB and Intake mani are the only things that's skimped on, any ideas??
Also this set up will be ran on Race gas (F&L 110)
Old Jul 22, 2014 | 09:22 PM
UncleD's Avatar
There is no such thing as "fully built."
Please people....stop using these retarded terms..
Old Jul 23, 2014 | 08:18 AM
OK "Clean rice" whats your "Definition" or "Opinion" of Fully built?! It uses a stock head and stock block and stock crank so that makes it not fully built?! funny but I guess everyone has there Opinion about things.....
Old Jul 23, 2014 | 11:03 AM
AllMtrRex's Avatar
LOL. He is saying the term doesn't make sense."Fully Built". It's like saying that engine is "Built all to hell"...it's slang and some consider it stupid. I find is stupid and funny at the same time. Nevertheless, good luck with the build.
Old Jul 23, 2014 | 11:38 AM
Lol by no means is it a race motor build, just something to have fun with, maybe I should change the title to" a healthy B16B build" lol
Old Jul 23, 2014 | 01:50 PM
UncleD's Avatar
Fully built
Poor mans R
Frankenstein
Mini me etc..
All stupid. Just call it what it is and quit with the retarded nicknames that teens made for them back in the 90's.
Old Jul 23, 2014 | 08:04 PM
viperjng's Avatar
Hi,
Nice build tho I did observe something which did not make sense to me. Feel free to correct me.
1> High Compression pistons in a turbo build ? Am i missing out on something thought turbo builds generally have low compression pistons.
2> Isnt the power its making a bit less. Am making 245 whp in my NA civic on 91 Octane fuel with 10.5:1 compression
No offense just something that I thought was not right.
Jignesh
Old Jul 24, 2014 | 06:14 AM
Not a turbo build, This is a NA build, my old set up is turbo, maybe that's why u think its turbo. The pictures I posted is what is in the car now, and will be pulled out once new motor is finish.
The WHP I posted is what my ls/vtec turbo is making right now.
Old Aug 13, 2014 | 07:20 AM
Bottom end is just about done, just waiting on the head from portflow. Coming along great.
Old Aug 13, 2014 | 08:13 AM
TheShodan's Avatar
Moderator
Originally Posted by viperjng
Hi,
Jignesh
Not as much anymore. because of advancements in tuning options, capabilities and fuels. MOST now are going at minimum 10.0:1 for static compression for turbocharger builds. Although it does depend upon the purpose of the car and who is tuning the engine. But that "low compression" thought process went out the window a bit over 10-15 years ago.
Old Aug 20, 2014 | 09:12 AM
Will be ready this Friday!
Old Aug 20, 2014 | 10:24 AM
rexB20vtec's Avatar
at the moment from what I read the skunk2 ultra series mainis pretty good for n/a builds or you can go with a gato mani
Old Aug 22, 2014 | 09:56 PM
Thatk20life's Avatar
what intake is that?
Old Aug 22, 2014 | 10:32 PM
kingofbattle909's Avatar
Nice build!
She must be fun to drive
maybe going turbo with that comp. would not be a bad idea..
YOu'd get better fuel mileage forsure even more so if you get the LS 5th.
I think Inline4 has a few sets on hand.
Old Aug 25, 2014 | 12:52 AM
BYE_BYE_V8's Avatar
Bimp
Old Aug 27, 2014 | 07:10 AM
So here are a couple of photos from the past few days, took the old ls/vtec out the car on Friday night, then worked on getting everything off the old motor that needs to get put on the new motor, My hondata s300 just came in yesterday, I'm waiting on new motor mounts to come in as well as a new flywheel. I should have new motor installed by Friday, I still need to call Church's Automotive to set up a Dyno appointment!
Any ideas on a header, I was thinking on just getting the skunk2 header!? any input would be nice
Old Sep 6, 2014 | 05:15 PM
Just got it dynoed today!
Old Sep 6, 2014 | 09:18 PM
rexB20vtec's Avatar
Nice numbers and nice build
Old Sep 26, 2014 | 04:57 PM
43!'s Avatar
43!
Good work.
70mm TB?
How do you like your brake setup? Thinking about those lately.
