How hot is too hot for an engine?
Old Jul 21, 2014 | 02:43 PM
CivicMatt94's Avatar
Default How hot is too hot for an engine?
I have a 99 Civic and at random times, mainly when still, the temperature needle will move from half way or less than half into the 3/4ths range. I have it looked at, but they tell me it's fine. The problem is I get either "it's fine" or "don't let it get too hot". So what exactly is a point that I should be concerned about?
Old Jul 21, 2014 | 02:45 PM
spoolymcgee's Avatar
Default Re: How hot is too hot for an engine?
Look into upgrading your thermostat.
Old Jul 21, 2014 | 03:03 PM
grumblemarc's Avatar
The Grumpiest
It should NOT be that high. Mine barely gets close to the halfway point and I'm boosted.
Old Jul 21, 2014 | 03:13 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I had this same issue with my 98, engine would show overheated within a minute, but wasn't even warmed up, needle would bounce all over the place, replaced the sender, but that wasnt the issue, I had seen something about a voltage regulator built into the cluster circuit board, thats the only explanation I could ever come up with made the gauge act crazy
Former User's Avatar
You engine is severely overheating or your temp gauge circuit is faulty. Assume the former for safety's sake.
Old Jul 21, 2014 | 03:15 PM
you need a reference temp gauge to compare against your gauge in the cluster
Old Jul 21, 2014 | 03:54 PM
That's what I was thinking considering that most of the time it is at half/less than half. I figured something must be going wrong if it the temp can increase by 1/4 or more. I'm no expert though so I figured I would go to a Honda forum.
Old Jul 21, 2014 | 06:21 PM
tony_2018's Avatar
Fish Twig
I dunno, looks fine from where I'm sitting...........
Old Jul 21, 2014 | 06:50 PM
thermostat only sets the minimum temp the engine will run, not the maximum, and you cant take it out, the engine has to reach a certain temp for the oil to boil off condensation, and for the computer to go into closed loop. it's also designed as a restriction to give the coolant enough time to transfer heat in the radiator. once it opens fully, it pretty much stays open, unless you are in a blizzard in the middle of south dakota for example
Old Jul 21, 2014 | 08:33 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The sender could be bad. The radiator could be clogged. The fan could be coming on too late. The water pump may be old and damaged. Etc. Etc. Etc.
dglassmyer
Apr 27, 2010 08:14 PM
klinster
Sep 23, 2009 04:19 PM
mnskateboarder
24
Jun 23, 2009 08:28 AM
integraslut78
Aug 13, 2008 10:35 AM
