Intermittently getting Buzzing when Starting
Once in a while I get a buzzing sound when starting my EF and will not crank. The motor will start if I try it again. Just wondering if this is a problem that needs an attention right away.
Thanks in advance.
Thanks in advance.
Yes and no. You don't want to be stranded, do you?
Is it buzzing from under the dash area? Maybe by your left knee? IF so, probably the main relay going pootsy. Could be a ground wire. Clean your engine/chassis grounds. Worst case scenario you'll need a starter (2 bolts irrc). Probably a ground/main relay.
Mine has done that for over 10 years. I want to also say the crx before did that as well. I've never had it turn into anything and my car has always started, but have always wondered myself. Seems as through I somehow blame myself for not turning the key fast enough LOL
i_VTEC
Jul 19, 2008 09:06 AM
reno96teg
Apr 23, 2008 01:52 PM
Junkyard2000
Jul 4, 2005 10:55 PM
