OK FS: 2000 Civic JRSC D16Y8 3K
Well I am out of the game for now I guess. This was my first car when I turned 16 and have had it ever since. All parts, modifications and maintenence have been done by me for the past 12 years. Approx. 160,000 mi original motor. Here are a few pics and a list of modifications that I can remember. 3K obo
2000 Honda Civic Ex (D16Y8)
ENGINE:
Ported JACKSON RACING Supercharger (roots style) @ 6lbs
ARP Head Studs
COMETIC Head Gasket
RACTIVE Header
INNOVATIVE Test Pipe
MUGEN Twin Loop Exhaust
BLOX 70mm Throttle Body
HONDATA Heat shield Intake manifold gasket
Custom Stainless Steel Short Ram intake w/ molded NACA duct from front bumper
Adjustable Fuel Pressure Regulator w/ water filled gauge
DSM 440cc Fuel Injectors w/ Honda Resistor Box
HONDATA S300 v1 in P28 ECU w/ OBD1 conversion harness
INNOVATIVE Broadband O2 Sensor w/ Gauge
ENERGY SUSPENSION Polyurethane Engine Mount Inserts
TRANSMISSION:
5sp Manuel conversion (was auto)
FIDANZA 9.5lb Flywheel
EXEDY Stage 1 Clutch & Pressure Plate
SYNCROTECH Carbon Coated Synchro's
SUSPENSION:
BUDDY CLUB Racing Spec Coilovers (16 way adjustable w/ adjustable spring pre load and ride height)
ENERGY SUSPENSION Polyurethane Bushings
SKUNK2 Adjustable Camber Arms (front)
BUDDY CLUB Adjustable Camber & Toe Arms (rear)
Honda Civic Si Rear Sway Bar (factory)
RACTIVE Strut Tower Bar (front)
Custom Square Tubing Strut Tower Bar (rear)
5mm Wheel Spacers x 4 corners
ARP Wheel Studs
Light Weight Open Ended Lug Nuts
Light Weight SPOON Replica Rims 15"
BLOX Rear Spherical Trailing Arm Bearing/ bushing
BRAKES:
STOP TECH Drilled & Slotted Rotors x4 corners
Integra GSR Rear Disc Brake Conversion
HAWK Brake Pads x4 corners
Braided Stainless Brake Lines
Honda 40/40 Proportioning Valve
EXTERIOR:
Honda Stanley Civic Type R Headlights w/ functional City Lights
MUGEN Grill
Carbon Fiber Sunroof Plug
Removed Badging
Mesh Grill Inserts in Front Bumper
Removed Pin Striping
INTERIOR:
BUDDY CLUB Racing Buckets
BUDDY CLUB Adjustable Seat Rails
SAFETY Racing 5pt Harness
EK4 Gauge Cluster
SKUNK2 Weighted Shift ****
Type R Style Shift Boot
Volt Meter/ Air Fuel Ratio/ Oil Pressure/ Water Temp Gauges
Removed most of interior from the seats back
ALPINE Head Unit
KENWOOD 6" 2 Way Speakers
350mm Dished Suede Steering Wheel w/ SPARCO Adapter
VIPER Alarm w/ 2 Way remote/ pager
1x Civic Si 15" Spare Rim w/ good tire
PM Me for any questions. I am located in Lawton, OK.
ENGINE:
ARP Head Studs
COMETIC Head Gasket
RACTIVE Header
TRANSMISSION:
SUSPENSION:
ARP Wheel Studs
BRAKES:
EXTERIOR:
MUGEN Grill
Removed Badging
INTERIOR:
EK4 Gauge Cluster
ALPINE Head Unit
Last edited by HCivExoo; Aug 3, 2014 at 08:53 AM. Reason: update price information
The track is the famous Nurbugring, it was when I was in Germany.
I drove it to North Carolina and South Carolina and Back to Oklahoma last year, it can make the trip.
Please see here: http://hondamarketplace.com/announcement.php?f=42&a=43
91ls-v
Dec 2, 2011 09:43 PM
