transaxle housing leaking
Old Jul 20, 2014 | 02:25 PM
the_tensl's Avatar
Default transaxle housing leaking
so a few years ago i hit a parking block with a piece of re bar theres no damage i can see to the outside of the housing, now it makes an inconsistent but subtle knocking and it has a very slow leak it hasnt affected the driving at all. I was wondering if maybe i just hit it a little loose or shifted one part (cos it bolts together sideways). could i maybe loosen it and try and straightening it out? any help appreciated thanks
95 accord lx a/t
Old Jul 20, 2014 | 02:44 PM
94 accord typeR's Avatar
Default Re: transaxle housing leaking
could also be a hose. get under there and CLEAN EVERYTHING. when its nice and clean eventually u will see new fluid dripping. follow that to the source and go from there
Old Jul 20, 2014 | 02:56 PM
the_tensl's Avatar
its dripping in the middle where the housing bolts together, thats why im wondering if i just shifted one side over and i can just loosen and adjust it back together
Old Jul 20, 2014 | 03:24 PM
MAD_MIKE's Avatar
MM Gruppe B
What color is the fluid?
If its red its ATF, if its tan/brown its oil. Most likely to be a rear main is leaking. When the RMS leaks it will dribble onto the bottom center of the trans case.
Old Jul 20, 2014 | 05:55 PM
trans must be removed to replace Rear Main Seal
tobytigger
May 28, 2015 07:10 AM
cb900f2
Aug 3, 2007 07:13 PM
zerogt86
Jul 6, 2005 04:26 AM
ewing86
Nov 12, 2004 03:28 PM
Syner-G-Racing LLC
Mar 23, 2004 08:38 AM
