Pin A11 boost solenoid
Old Jul 20, 2014 | 02:12 PM
accordturb96's Avatar
Default Pin A11 boost solenoid
can anyone post a picture on how to add the pin to A11. Im not sure exactly where and how it is added. I know which one A11 is but what is confusing is do I install the pin into the conversion part of the harness where there is no current pin? Is the boost output controlled from the signal returning from the EGR components or does the ecu use it? Thanks in advance, I cant seem to find a picture of anyone installing it
Old Jul 20, 2014 | 08:14 PM
holmesnmanny's Avatar
Whats a boost solenoid? A11 is the egr solenoid. What is it youre trying to do exactly?
Old Jul 20, 2014 | 08:28 PM
Default Re: Pin A11 boost solenoid
Sorry buddy. I'm installing the solenoid that controls boost via hondata. Boost by gear. I call it the boost solenoid. PWM solenoid. Instructions state to add a pin to a11 of the obd1 harness. This is for the f22b2 I have the proper ecu and hondata installed already. Just confused on what exactly you Install to wire the electronic boost controller. Hope that is more clear
Old Jul 20, 2014 | 08:30 PM
On my conversion harness I have an open spot which is supposed to be a11. But that is the side of the conversion harness that has nothing exiting the ecu for the egr at a11. I'm curious what and where I tap into the line to control the boost controller. How is the divice controlled exactly? Am I piggybacking the egr stuff by doing that. Just confused haha
Old Jul 20, 2014 | 09:56 PM
oh gotcha, can't say i can help you with this lol
Old Jul 20, 2014 | 10:22 PM
NerfGunner420's Avatar
brand? name of the actually solenoid
Old Jul 21, 2014 | 05:40 AM
It's the blue colored solenoid you order when you get hondata from phearable. I had him add the components to the ecu and I just need to wire it to the ecu to control the device
Old Jul 22, 2014 | 09:38 AM
GhostAccord's Avatar
If there is no wire coming out of Pin A11 at the ECU then you have to add it there.
As far as the rest goes. Are they suggesting that you use the stock EGR wiring in the engine bay and wire harness to hook up to the solenoid?
Old Jul 22, 2014 | 03:08 PM
Well the adapter harness I have to get my obd1 ecu Into the car had a wire exiting a11 and heading to another spot on the other side of the adapter. I'm wondering If I just depin it and commandeer the spot and run that output to the controller if that would work. I'm assuming the egr components aren't truly used in this case with boost anyhow.
boosted1996
Dec 29, 2015 04:15 PM
WAUKEENEM1
Engine Management and Tuning
Apr 5, 2013 07:54 PM
IntegraFanatic
Sep 16, 2003 06:17 AM
IntegraFanatic
Sep 9, 2003 12:18 PM
