98 honda civic coolant keeps getting air
Old Jul 20, 2014 | 09:28 AM
Thornton121's Avatar
Default 98 honda civic coolant keeps getting air
98 honda civic y7 five speed keeps getting air in the coolant lines I have bypassed the heater core thinking it was that but still seems to b getting air in the lines has no coolant leaks also have burped the radiator for over 45 mins at a time from the cap and from the bleeder screw what could be the issue bad water pump? Water pump doesn't make any noise at all though.
Old Jul 20, 2014 | 09:31 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 honda civic coolant keeps getting air
"Seems" or "is"? Don't speculate. Pressure test the system.
Old Jul 20, 2014 | 10:04 AM
Former User's Avatar
Possible blown head gasket. Do you see bubbles in the coolant in the reservoir and radiator?
Old Jul 21, 2014 | 08:23 AM
Only see bubbles in the radiator everytime I bleed the system u can tell it's not working keeps on burping for well over a hour
Old Jul 21, 2014 | 08:37 AM
Schister66's Avatar
Man U FTW
My first thought as well. If the HG is blown, exhaust gas would make its way into the coolant system and constantly bubble like you're saying.
Old Jul 21, 2014 | 11:08 AM
eghatch9295's Avatar
Stancetard Hate Monger
yep. rent a block tester to confirm. will tell you if the bubbles are just air or exhaust gases. if exhaust gases, probable blown head gasket.
nc2wheels
Dec 4, 2011 11:30 PM
panchlow
May 2, 2011 05:06 PM
Empyre JDM
May 17, 2010 10:18 PM
dhn
23
Jan 5, 2008 01:06 AM
giantdny
Nov 6, 2006 07:13 AM
