k series fly buy wire to b18c
you may be the only one who wants to do this.
this will take a lot of skill to pull off. you may need to use your high skill level to design an adapter. shouldn't be hard considering.
I have a K dbw throttle body sitting at my house. Need to start figuring out the logic, it really shouldn't be that hard. It will require its own microcontroller though.
Haven't even looked to see what is needed to physically adapt the tb to the b manifold though.
Sorry maybe I should have explained more the reason I am wanting it as I am going to run sleeved b18c into the rear of this mini effectively making it rwd ,..
I will be running a link or vipec ecu which I believe has outputs for dbw so ive thought maybe I should go that way instead of cable ,...
Just not sure if everything is compatible , i suspect no ,...
I think skunk does a 70mm dbw throttle body for k series Id need pedal assembly but not sure about anything else
i would start with a throttle body gasket from each engine. cheap ones, just for the pattern. use those to start the design process.
Alexpbnj
Nov 14, 2010 12:51 PM
cpl rampage
23
Apr 22, 2009 03:44 AM
