98 accord idles at 2000 rpm
Hey guys new here I have a 98 accord with a f23a1 I have searched and called around and cant find a solution to my problem so before you start saying search dont im not some noob who cant search so with that as side recently my car has been idling at 1500 with the idle turned all the way down I was told the iacv so I cleaned it, jow it looks like new cleaned the mounting surface and all then reinstalled it then my idle went up to 2000 not moving I bled the coolant system and checked for air leaks couldnt find any all vacuum lines are good the only codes im throwing are p0325 but I have a brand new knock sensor any help is greatly appreciated
the fast idle thermal valve (FITV) might be letting be closing
put your finger over the lower port (hole) and see if that lowers your rpm
pic is for reference only, it doesn't have a FITV
So cleaned my iacv with wd40 again and let it soak for a bit and adjusted my idle up a hair not its idling at 1000 when its warmed up gunna try it in the morning and see if it stays
