91 crx wont start after swap. help
Old Jul 19, 2014 | 12:03 PM
HondaCRX1991Si's Avatar
Default 91 crx wont start after swap. help
just did a motor swap as i bought the car as a shell. i swapped a d15b2 non v tec with skunk 2 im and the stock si mpfi harness. pm6 ecu and kept everything obd0. my started signal fuse doesnt get power so the car wont crank. i ran a "hotwire" to the fuse and it will crank but no start.a few things i have noticed is there are 2 wires on the ecu plugs look cut but there are no extra inlets on the plug itsself? 1 white/yellow and 1 white with silver dots. are these necessary? also under the dash by the clutch there is a white 4 prong plug that i can not find any info or as of where it may plug into.. those wire colors are black/red black/white black/white and a smaller wire which is blue and black.
Old Jul 19, 2014 | 12:06 PM
Default Re: 91 crx wont start after swap. help
any help would be awesome. im just running to a dead end and know honda tech would be the best place for answers. i can email pics if needed
Spug
Apr 5, 2012 09:44 PM
K20AllMotorEF8
Feb 22, 2012 10:33 AM
B18C1-ED8
Feb 21, 2006 05:14 PM
BoRiCuA
18
Jun 21, 2004 12:15 PM
