Radiator Fan Wont Shut Off
Old Jul 19, 2014 | 09:09 AM
ScubaNole's Avatar
Default Radiator Fan Wont Shut Off
Need Help. We had motor replaced in car 1996 Honda Accord VTECH. Shop did great job. When we picked it up they stated that radiator had leak and condessor fan was bad. Filled radiator up and drove home fine. Car sat for a week waiting on a new radiator and condessor fan. Put both in. Started car to check for leaks and had son turn AC on. When he did radiator fan came on and would shut on/off with AC. Condessor fan never came on. But when the car is turned on the radiator fan runs and does not shut off. The only way to turn off is pull the fuse.
Old Jul 19, 2014 | 02:21 PM
holmesnmanny's Avatar
Disconnect the fan switch connector at the thermostat housing to see if maybe the switch is stuck in the closed position.
Old Jul 20, 2014 | 01:32 AM
Otherwise the fan timer could be bad I would disconnect that.
Old Jul 20, 2014 | 08:37 AM
Lost Again's Avatar
Default Re: Radiator Fan Wont Shut Off
So the new cond fan (left/drivers side) did not come on when the ac was on? Sounds more like a relay issue.
Just so I'm understand what is going on with the rad fan (right/pass side). Key on, fan on. Key off, fan off......
Old Sep 12, 2019 | 07:44 AM
DRELECTRIC's Avatar
I HAVE A 1994 HONDA ACCORD DX I HAVE REPLACED BOTH COOLANT TEMPERATURE SWITCHES AND BOTH COOLING AND CONDENSER FANS, SWAPPED BOTH FAN RELAYS, AND WHEN I SWITCH THE CAR OFF THE COOLING FAN COMES ON AND CONTINUES TO RUN FOR OVER 16 MINUTES.....IS THERE A TIME LIMIT SWITCH FOR THIS? IF SO WHERE WOULD I FIND IT ?
Old Sep 12, 2019 | 08:37 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Please do not type in all CAPS, it denotes yelling.
The radiator fan control module is located behind the glove compartment.
DaveyBob
May 25, 2016 01:03 PM
Tdawg_1993
Jun 30, 2015 04:33 PM
adamrich33
Apr 2, 2012 04:00 PM
imbest123
Oct 24, 2011 06:14 AM
Oknoe.
May 6, 2010 03:43 PM
