Collision Repairable?
Old Jul 18, 2014 | 04:59 PM
Bleakened's Avatar
Icon5 Collision Repairable?
A while back I hit someone while it was raining (their fault) and my driver side front corner went into their passenger door at roughly 25 mph.
I accepted $500 from them for me to disappear and now I'm thinking I shouldn't have... My new front end doesn't line up properly due to the core support being dented in and all and had someone tell me my frame is probably irreversibly damaged.
Is there any practical way to repair some light frame damage up front to make my front end line up again? Am I going to have to buy and weld on a front clip like a few people told me?
I drive a 98 Civic Hatch.
TL;DR, front end doesn't line up due to collision. Most likely frame damage, is it repairable?
Old Jul 18, 2014 | 05:01 PM
94 accord typeR's Avatar
Default Re: Collision Repairable?
pics would help
Old Jul 18, 2014 | 05:05 PM
grumblemarc's Avatar
The Grumpiest
IKR? I guess we're supposed to guess at the amount of damage?
Old Jul 18, 2014 | 05:08 PM
Bleakened's Avatar
Well the question in mind is if frame damage is a reasonable repair, not so much if it is frame damage at all.
Here's a gallery of images I just took tho: http://postimg.org/gallery/3boaaswsg/6bf18734/
Old Jul 18, 2014 | 05:21 PM
B_Swapped93's Avatar
lol that's nothing not even frame damage looks like minor rad support bend...
Old Jul 18, 2014 | 05:23 PM
Bleakened's Avatar
That's good to hear, rad supports have to be welded on, correct?
Old Jul 18, 2014 | 05:28 PM
you can pull that straight(by hand) it's just the top part, the fenders can be slid in/out same with the hood not more then a few cm's at the most. But there's still wiggle room trust me trying to get the perfect fit for my old jdm front teg was not easy.
Old Jul 18, 2014 | 05:39 PM
Bleakened's Avatar
Should I try my hand at it with a rubber mallet maybe? Also, on the corner that got hit, the hood clips over the headlight. Should I just bend the headlight into a "normal" position after I do everything else?
Old Jul 18, 2014 | 07:04 PM
shotoutacc0rd's Avatar
Some body shops dont charge alot to straighten a frame, IV seen quotes for $500 to bring it into spec for "minor frame damage".
the one and only deciding factor is if the damage will cost more to repair than a new shell.
if its a Ferrari F40, Toyota GT2000 etc obviously it will be better to fix it no matter how bad it is.
if its a Honda civic, yeah, no.
Old Jul 18, 2014 | 07:10 PM
I suggest bringing it into a good alignment or body shop to have em measure to look for frame damage. If there's no frame damage, try reversing the bends or replacing the rad supports.
also, "rubber mallet" I have a feeling you will need a decent hammer and a 2x4 to prevent hammer marks
Old Jul 18, 2014 | 07:15 PM
Bleakened's Avatar
or just a decent sized wooden block, yeah?
Old Jul 18, 2014 | 09:59 PM
tony_2018's Avatar
Fish Twig
Wild suggestions for something we don't even know what it looks like....right.....heck why not.
OP take a plasma to it and cut the front frame off and spot weld the new radiator support to the fender and then you should be fine.
Old Jul 18, 2014 | 10:06 PM
lerks909's Avatar
Same thing happend to my civic somebody clipped my passenger side. My light housing sticks in a lil more than my driver side
Old Jul 18, 2014 | 10:15 PM
yeah, something that won't absorb too much energy but also will prevent the hammer from putting its own dents into the metal. Thats just a cosmetic thing tho if you're not worried about that just beat on it with whatever you've got, mallet hammer piece of lead pipe etc
Old Jul 19, 2014 | 07:58 AM
crazyhouse2011's Avatar
No.
Old Jul 19, 2014 | 04:40 PM
he posted pics
Old Jul 21, 2014 | 06:53 PM
demas16's Avatar
I work at a body shop and looking at your pics looks like u just need a little work with a slide hammer to pull that back in. once you get that where it needs to be your gaps for your fender to hood should line up better and a better headlight fit too. The rad support in also your headlight mounting panel. No frame damage from the looks its too high of a hit with not much damage
sleEK Hatch
Paint and Body
Feb 15, 2014 09:25 PM
crxguy406
Mar 10, 2013 11:12 PM
EGnutsJ
May 16, 2010 07:25 PM
B18Sleeper
Oct 20, 2005 12:33 PM
