SFWD PARTOUT manley, cp, tial, s372, darton etc...
Old Jul 17, 2014 | 01:21 PM
greenmachine567's Avatar
Default SFWD PARTOUT manley, cp, tial, s372, darton etc...
Parting out my sfwd project. Most parts are new and have only been installed but never ran. Im located in kentucky and local pickup is preferred on larger items but I can ship if necessary. If theres any questions or anyone wants more pics u can text me at 270 313 5873.
b18c darton M.I.D sleeved block (84.5mm) has just been decked, bored and honed. Has not been ran since machine work. Comes with mains/girdle, windage tray, gsr oil cooler, t-stat housing/crossover tube, water pump, type r oil pump(has about 300ish miles on it), rear seal and the oil squirters have been plugged for the use of an LS crank.-$900
Manley turbo tuff rods(LS). Brand new, they have only been installed. Comes with new acl race bearings.-$600
CP pistons, 9.7:1 (84.5mm). Brand new, comes with rings, wrist pins and wrist pin locks.-$450
LS crank. Never had a spun bearing, journal surfaces are mint. -$100
GSR ARP head studs. These are unused but they have seen one torque sequence during engine assembly.-$90
GSR ARP main studs. These were used once on a previous setup. -$45
Fluidampr street/strip crank pulley. Brand new never used -$250
BMC race 6 liter intake manifold. I bought this from a member on here but never got to use it. Its flanged to fit either a gsr or b16/type r. Has a 90mm throttle body opening and the flange is the "mustang" style. -$650
Exospeed star8s 15x10. I bought these fromna friend who had them as spares and nevernused them, and I also never got around to using them. They have hoosier slicks miunted on them but they are pretty worn out, I only used them as a reference to set up my suspension but I can have the tires dismounted if they arent wanted.-$600
Avid billet motor mounts for eg/dc. The driverside mount is for the 3 post mount. These are new and I believe they are 62a. -$180
Go autoworks catch can setup. Comes with x4 -10an lines/fittings, the fittings for the back of the block, and a purple powder coated vtec valve cover with x2 -10an bungs.-$350
SFWD turbo kit. I bought this from a member on here (facetuned) but I never got to use it. Itncomes with a custom forward facing twin scroll t4 manifold, bullseye s372 1.10ar exhaust housing, intercooler (garrett 950hp core) with custom end tanks, 3 inch coldmside piping with tial 50mm bov(silver), x2 tial mvs wastegates(black) with stainless dumpntubes, boost solenoid with all pushlock vacuum fittings, 4 inch bumper exit exhaust and all oil lines, couplers and t bolt clamps. This kit was made to fit behind a stock integra front end but I know that I will fit an eg with alittle persuasion/trimming the radiator support a little although a wide front end wouldmhave to be used unlessnu wanted to run no bumper. -$3000
Aeromotive fpr. New, I have -6, -8 and -10an fittings for it. -$100
BDL fuel rail (black) used but still in good condition. -$75
Gsr cams, used but all lobes are in good condition.-$75
skunk2 cam gears. Each one has 1 stripped bolt hole but I never had a problem with them. Im sure they couldnbe rethreaded but ill leave that to someone else.-$80
GSR head. Fresh resurface. Has blox dual valve springs, blox titanium retainers, stock valves, and stock ports. Comes with cam caps/rails, temp sensors, and vtec solenoid. -$750
Im sure ive missed some things but if theres any questions just text me. Thanks
Old Jul 18, 2014 | 07:54 AM
BoostedVtecEG's Avatar
Default Re: SFWD PARTOUT manley, cp, tial, s372, darton etc...
Got more pics of inlet and throttle bodie
Old Jul 19, 2014 | 06:00 PM
slowteg550's Avatar
Are those Tials 38s? Would you sell just the pair of them?
rwdkid
Feb 11, 2012 06:19 PM
JDM_JNKY
Feb 6, 2012 03:41 PM
X-Mazda 3 Racer
Mar 25, 2005 01:31 PM
