liter ?
Old Oct 31, 2002 | 06:55 AM
crackhead's Avatar
Default liter ?
wondering about wats the difference between the liters in cars for
example the lude 2.2 and gsr 1.8
Old Oct 31, 2002 | 07:03 AM
Soundwave9900's Avatar
Default Re: liter ? (crackhead)
the difference between 2.2 and 1.8 liters is .4 liters
Old Oct 31, 2002 | 07:21 AM
crackhead's Avatar
Default Re: liter ? (soundwave9900)
i meant smartass why is the lude 2.2, gsr 1.8, accord v6 3.0
and wat does it actually measure
Old Oct 31, 2002 | 07:32 AM
DISPLACEMENT
Combustion chamber
The combustion chamber is the area where compression and combustion take place. As the piston moves up and down, you can see that the size of the combustion chamber changes. It has some maximum volume as well as a minimum volume. The difference between the maximum and minimum is called the displacement and is measured in liters or CCs (Cubic Centimeters, where 1,000 cubic centimeters equals a liter). So if you have a 4-cylinder engine and each cylinder displaces half a liter, then the entire engine is a "2.0 liter engine." If each cylinder displaces half a liter and there are six cylinders arranged in a V configuration, you have a "3.0 liter V-6." Generally, the displacement tells you something about how much power an engine has. A cylinder that displaces half a liter can hold twice as much fuel/air mixture as a cylinder that displaces a quarter of a liter, and therefore you would expect about twice as much power from the larger cylinder (if everything else is equal). So a 2.0 liter engine is roughly half as powerful as a 4.0 liter engine. You can get more displacement either by increasing the number of cylinders or by making the combustion chambers of all the cylinders bigger (or both).
gdrew888
Jan 8, 2013 06:56 AM
thenext
Apr 15, 2011 07:56 AM
thecruzs2007@yahoo.com
Sep 27, 2009 12:08 PM
taengok
Sep 1, 2008 06:37 PM
t o m
Apr 8, 2004 10:30 PM
