Harness suggestions?
Old Oct 31, 2002 | 06:49 AM
xjohnx's Avatar
Default Harness suggestions?
Which 4 point harness would you reccomend? it will mainly be for Auto-X and light track duty.
I've been considering the Sabelt (below), any pros and cons to this one? Will this mount to the rollbar like most of the others i've seen?
Old Oct 31, 2002 | 06:52 AM
Reid's Avatar
Global Moderator
Default Re: Harness suggestions? (xjohnx)
Get a 5 pt Sabelt with a cam lock from Racer Wholesale.
Old Oct 31, 2002 | 06:54 AM
xjohnx's Avatar
Default Re: Harness suggestions? (Reid)
Will the 5 point require me cutting the seat? this will be on stock seats for a while.
Old Oct 31, 2002 | 06:56 AM
Reid's Avatar
Global Moderator
I would stick with the stock seatbelts and seat until I'm ready to make the jump to a race seat and race harness.
Old Oct 31, 2002 | 06:57 AM
sackdz's Avatar
Yes, if you have a rollbar you should mount the harness straps to that, you won't need any hardware kits for the top straps. For the lap belt, you can use the stock seatbelt mounts, and you will need a bolt in kit for both. (I think)
sack-who's getting a 5 pt sabelt with camlock from a h-t homie.
[Modified by sackdz, 10:58 AM 10/31/2002]
Old Oct 31, 2002 | 07:01 AM
sackdz's Avatar
No you may run the sub belt around the cusion although it won't be as effective. Be sure to mount it right below your ***.
Old Oct 31, 2002 | 08:10 AM
xjohnx's Avatar
Default Re: Harness suggestions? (sackdz)
Is there any advantage to the cam lock over the typical push/click style belt? sorry for all the dumb questions, but i'm a n00b when it comes to this harness stuff.
Old Oct 31, 2002 | 08:41 AM
Back in Black's Avatar
Rather OG
Convenience. However, the extra dough wasn't worth it for me, and the latch and link has worked fine.
[Modified by Jason Franza, 12:45 PM 10/31/2002]
Old Oct 31, 2002 | 08:49 AM
xjohnx's Avatar
Default Re: Harness suggestions? (Jason Franza)
I assume you mean the conventional (stock style) is more convenient? no safety benefit though? just cost?
Old Oct 31, 2002 | 09:55 AM
PiYoImuT's Avatar
what if I don't have rollbar?
Old Oct 31, 2002 | 10:00 AM
sackdz's Avatar
There's basically 3 types of latches. Camlock, stock style, and latch and link. Although I've never seen a 5 or point come in stock style. The one you've pictured above is stock style.
Reid's Avatar
Global Moderator
Cam lock is more convenient.
I prefer cam locks.
Old Oct 31, 2002 | 11:46 AM
PiYoImuT's Avatar
Default Re: Harness suggestions? (DOHC_VTEC)
hm.. but I want a harness for AutoX-ing.. and as of now, I can't put Rollbar inside my R since I need the rear seat for people.
Old Nov 5, 2002 | 03:37 AM
Rather OG
Default Re: Harness suggestions? (PiYoImuT)
[shameless plug]In case anyone is interested, I have two Simpson latch n' link 5-points available. One is used in black, and the other is new in bling-bling blue [/shameless plug]
Old Nov 5, 2002 | 06:02 AM
Dave-ROR's Avatar
I have two black camlock autopowers.. not sure if I wanna sell em tho.
trevorjohn88ef
Jul 19, 2008 04:09 PM
Race Egr
May 8, 2005 05:09 PM
White Dragon
Aug 14, 2003 09:47 AM
DevilSolSi
Oct 30, 2002 08:31 PM
92SiB18C1
Sep 3, 2002 05:15 PM
