cable too tight?
Old Jul 16, 2014 | 06:09 PM
Foodstamps's Avatar
Default cable too tight?
got a small issue guys I got a 91 civic with a obd0 b16 installed by me I'm using the 91 Integra clutch cable it barely fit on the transmission but worked after I got it on the clutch engages when the pedal is almost completely retracted so I decided to tighten it up little bit now I'm grinding when I go into reverse and it feels a little bit harder to shift into gears not as smooth as before could the cable be too tight? also is my clutch bad because on my 03 Civic getting gauges a lot closer to having the pedal pushed the floor?
Old Jul 17, 2014 | 04:32 AM
Freemananana's Avatar
Default Re: cable too tight?
You may have over tightened it.
This should help
Your '03 is probably hydraulic anyways, not really applicable. Also, the factory 88-91 civic clutch cable works too.
EFjoe91
23
Jun 9, 2014 04:40 AM
same ol Steve
May 10, 2009 05:18 PM
efrex
Nov 5, 2005 06:45 PM
DAmn
Jul 21, 2005 10:27 PM
InJ3cted
May 24, 2005 02:16 PM
