FS: COMPLETE 92 EG Si part out
*** EVERYTHING IS OR BEST OFFER***
*** ALL BODY PANELS ARE RED***
***THE MORE YOU BUYER THE MORE I LOWER THE PRICE***
*** LOCATION APPLETON, WI***
***PLEASE TEXT ME AT 920-819-5137 IF YOU HAVE QUESTIONS OR YOU WANT PICTURES***
***PLEASE TEXT ME, I REPSOND A LOT FASTER***
1. Mint Front and rear seats = $100
2. Mint carpet = $50
3. Mint seatbelts = $10 each $30 for all 4
4. Rear side interior trim pieces = $10 each
5. A pillar with the rear window interior trim piece = $10 each
6. Glove box = $10
7. Cup holder = $10
8. Both rear quarter glass = $10 each
9. Complete front doors (with door panel, window, regulator, crank handle)
a. Super mint, no rust on lower seam except passenger side has 1 rust spot on outside the size of a quarter
b. = $40 each or $60 for both doors
10. Complete Front End = $100
a. OR
b. Hood (OEM) ( no big dents or dings, just rock chips ) = $30
c. Fenders (OEM)( driver side mint except passenger side has 2 surface rust spots about 3 inch long by 1 inch) = $20 each or $30 for both
d. Headlights (OEM) with bracket = $15 each or $20 for both
e. Corner lights = $5 each or $5 for both. LOL.
i. Drive side has a crack in it but no water leak
f. Front bumper support bar with foam = $20
11. Sunroof with motor = $75
a. Was in perfect working condition when I pulled it and the glass is mint with no scratches or chips
12. Headliner with sun roof inner seal = $20
a. Super mint except I punched a small hole from removing 1 clip and one **** handle bolt wouldn’t come off so we had to take the head liner off around it. Will send you pics if requested.
13. Si Dashboard = $50
a. Super mint and complete with climate control BUT DOES NOT HAVE THE BEZEL AROUND THE CLUSTER.
14. Rear disk brake conversion with 40/40 proportioning valve = $120
a. Trailing arm bushings are garbage but other than that its complete with the brackets and ebrake cables.
15. Hood latch assembly with cable = $20
a. Still in working condition when pulled
16. Rear Si Glass with wiper arm assembly and trunk stays and harness = $50
a. Rear wiper motor was working when pulled
17. Rear tail gate assembly = $50
a. No rust complete with inner plastic trim but the trim is pretty beat up
18. Rear tail lamp assembly OEM = $20
a. Right out tail lamp assembly has 1 chip in it but is covered with super glue. No water intrusion
19. Complete Z6 LONG BLOCK (MILEAGE IS 160K) = $350
a. It’s a complete engine minus the trans and clutch assembly
b. Also comes with engine harness (uncut), axles, linkage, mounts and a virgin p28
c. Brand new aftermarket dizzy with cap, rotor and ign module
20. Side skirts = $10 each or $15 for both
a. Mint and I have about 6 clips to go with them
21. Roof drip moldings = $10
a. Mint and I have about 8/10 clips to go with it.
22. Subfram with p/s stuff still connected and sway bar = $100
https://fbcdn-sphotos-h-a.akamaihd.n...45057007_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...73805281_n.jpg
https://scontent-b-lga.xx.fbcdn.net/...28572346_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...53450541_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...40801734_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...53464183_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...91281933_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...7b48e8277ecbc9
https://scontent-a-lga.xx.fbcdn.net/...98501572_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...48068677_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...90024878_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...81161579_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...05804479_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...10061297_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...56719634_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...35530083_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...07993770_n.jpg
https://scontent-b-lga.xx.fbcdn.net/...c7&oe=54564A5E
https://fbcdn-sphotos-f-a.akamaihd.n...328c49235f19f1
6. Glove box = $10
7. Cup holder = $10
a. OR
Front Bumper, LF fender, Carpet, Front and rear seats, Side skirts, roof drip moldings, driver side fender liner all sold. MORE PARTS NEED TO GO!!!! COME GET THEM!!!!!
ReDrAnGeR
Dec 16, 2010 10:05 AM
