Clutch issues
Ive got a Clutchnet clutch HD PP, street disc, in my civic, and when im at the track and hit the nitrous it slips very bad after i shift, but when im on the street and race it doesnt do it and works fine. Whats going on here?
Are you using the nitrous on the street?? I am not too sure what is going on. I think it is kind of weird that the surface raced on would make a difference in whether the clutch would slip or not because you aren't making any more power while on the track.
are you on slicks on the track?
Tracks can cause a clutch to slip worse than it would on the street because of the better surface....especially if you're on slicks.
i think its the street disc. try upgrading to a more aggressive disc such as a kevlar disc or a puck/sprung style disc.
those are more suitable to racing conditions.
car is setup identical on street/track ..street tires, both runs were with the nitrous
ive made 3 passes down the 1/4 with the n2o....clutch slipped all 3 passes through just about every gear
Only raced once on the street with the nitrous and held up fine
exospeed: i see you sell clutches...what would be a good clutch setup for me to purchase and what would it run me for $$ , car will be seeing some slicks passes next year, and a bigger n2o shot, and also daily driven
[Modified by Bottled EF, 5:11 PM 10/31/2002]
since you are stepping up to more NOS and more abuse to the clutch, I'd go with an ACTION 1MD sprung disc kit. this should be fine for 50-100 shot NOS and on slicks.
if you want somethign alittle more aggressive, the solid disc is another option.
these run about $325.00 for a complete kit.
with these puck style discs, they can handle the hard burnouts you have to do with slicks.
broke 2 trannies with an ACT. never again.
unless you are just street driven and dont race at all, maybe ACT is good but then again, why get a performance clutch.
LSVTEC 91 Civic
May 20, 2005 04:31 PM
