What do you call this part?
Old Jul 15, 2014 | 06:16 PM
Garry_90Civic's Avatar
Default What do you call this part?
What do you the call the panel that the lock for the hood is mounted? It's a little bit bent so the hood doesn't pop up by itself without my help.
Old Jul 15, 2014 | 06:49 PM
SleepyEF's Avatar
Default Re: What do you call this part?
Its called the t bar. Most efs have this problem. I got a come-a-long or racthet strap and went around a tree and bent it out a little problem solved or try your luck at junk yards
Old Jul 15, 2014 | 09:17 PM
4drEF's Avatar
Keyboard Humorist
It's proper name is the upper radiator support or the bulkhead upper frame.
The vertical piece to the 'T' is the bulkhead center stay.
Old Jul 16, 2014 | 07:08 AM
Thanks
Old Jul 16, 2014 | 08:10 AM
whited's Avatar
CRX God
What your not going to tell him he needs to replace the engine also?
Old Jul 16, 2014 | 08:14 AM
4drEF's Avatar
Keyboard Humorist
He was very clear to say "What do you the call the panel that the lock for the hood is mounted?"
The engine isn't that part.... butttt.... if he dropped a K motor or a J motor in there, then he could just leave the hood off for engine clearance. Problem solved!
ej6kevin515
Jan 23, 2012 07:24 PM
HONDA_CIVIC_HATCH_Boy
Feb 27, 2006 12:04 AM
CHiNEzEB0Y
Apr 8, 2005 07:29 PM
^R@m!r0_(M)
10
Mar 5, 2004 08:42 AM
Bodman
Jul 21, 2003 12:00 PM
