Classic Hondas All Pre-1988 Hondas.
84 Honda Civic Wagovan A/C compressor
Old Jul 15, 2014 | 01:44 PM
Rattastic2231's Avatar
Default 84 Honda Civic Wagovan A/C compressor
I was told by an Independent honda shop that the type of A/C compressor (Airplane style as they called it) i have cannot be converted to R134A. I was hoping to get a second opinion on this and was wondering if anyone had any other ideas on how i could get some A/C in this car. (aftermarket compressor maybe? i'm not sure)
Thanks in advance.
Old Jul 16, 2014 | 09:46 AM
ej1995's Avatar
Default Re: 84 Honda Civic Wagovan A/C compressor
sounds wierd...i'm not 100% certain on your particular application, but you can convert pretty much anything that was R12 to R134A
Old Jul 16, 2014 | 12:14 PM
They just told me that there were two types of compressors for older honda's, and that one doesn't work right/work well with 134A. I might just try to convert it anyways, because i really was hoping to have A/C.
I still would like some more opinions. It's the japan model FWD wagon. I just looked on Hondapartsnow.com, and the two brands of A/C compressors are Keihin and Sanden, which doesn't help since i don't know which mine is.
Old Jul 16, 2014 | 01:05 PM
ej1995's Avatar
from my experience, they are usually tagged with the manufacturer info on them.
Old Jul 24, 2014 | 11:05 AM
williamtii's Avatar
It wont work as efficiently but it will still work. The Expansion valve is where you might run into trouble. You might try an R-12 equivalent such as Duracool. Works awesome in my old R-12 system Volvo.
The real question is what kind of shape is your compressor in now? How long has the system been dead for? Most shops dont want to touch ancient dead AC systems for good reason. For *them* to get it up to snuff would cost *you* double the value of the car.
Best to do the hard parts yourself. New O-Rings, Accumulator, Compressor and a good system flush. Button it up and take it to a shop to vac, fill, and test.
Old Aug 4, 2014 | 09:14 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Second vote here for Duracool or equivalent (called "R-12a"). This will get around the problematic R-134a conversion.
Best if you do this work by DIY. In fact, an A/C shop won't go near a Duracool retrofit even though it is probably the best solution in your situation.
EM2Civic
Jul 16, 2010 02:51 PM
97civic78
Apr 13, 2008 06:18 AM
himhimself
Jun 14, 2007 05:27 PM
himhimself
Jun 14, 2007 03:46 AM
