Accord 3rd clutch switch part# and location???
Old Jul 14, 2014 | 07:59 PM
killerklown's Avatar
Default Accord 3rd clutch switch part# and location???
First post and first Honda!
2002 Accord EX V6 Auto
Pulled a code for third clutch switch on the car.
Im not sure which one on the tranny this is. Local Honda dealer was less than no help. Then he said its not in his parts book. I guess maybe its named different between parts/service manuals.
Anyway I need a part number and a way to determine which is for the third clutch. My service manual had one little paragraph on this and the image wasnt much help to a honda rookie...
Thanks for you help in advance. ..
Old Jul 15, 2014 | 06:25 AM
forward's Avatar
Default Re: Accord 3rd clutch switch part# and location???
Go here and you can look at all the parts for your car, and get part numbers and prices: http://www.hondapartsnow.com/2002-ho...ord-parts.html
Maybe directly here: http://www.hondapartsnow.com/Page_Pr...2970%201472011
Old Jul 15, 2014 | 03:04 PM
MAD_MIKE's Avatar
MM Gruppe B
If you are looking for the 3rd gear pressure switch it is called a 'oil pressure switch' under transmission parts probably under 'solenoid/swtiches'. There are two on the trans one for 2nd and one for 3rd.
http://www.gvrdeu.org/Honda%20FSM/Ac...ccord%20SM.pdf
Skip to page ~500 to get to the AT transmission.
Keep going til you find diagnostics for your code. Follow the procedure to check harness/pins/etc.
Part #14 on the below diagram. Sorry dunno which one is for 3rd and which for 2nd. Look for leaking, might just need #16 if there is a pressure issue. Look for damage to the wire harness and
Old Jul 15, 2014 | 03:33 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The 3rd clutch pressure switch on a V6 is on the underside of the vehicle, front of transmission.
Just for informational purposes, the 2nd clutch pressure switch is on the left side of the V6 engine, on the transmission and higher up.
For the 6th generation Accord V6, both pressure switches are the same Honda part number.
Old Jul 27, 2014 | 05:13 PM
Is it visible from under the hood when popped? like where is it in relation to say the dipstick or something?
Old Jul 27, 2014 | 05:14 PM
someone needs to snap a photo pointing at it...lol
maybe for real...
even the pic in service manual isnt helping if im not exactly sure where to look....
HELP!
Old Jul 27, 2014 | 05:21 PM
94 accord typeR's Avatar
under side of vehicle front of trans near the radiator. jack the car up on the trans side (driver) and u should be able to find it
Old Jul 27, 2014 | 05:41 PM
So if I ever do find it (doubtful), will fluid continue to leak out if I remove it? Or only if car would be started?
Still might need a photo.....
Old Jul 27, 2014 | 06:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I will temporarily post the photo.
Service manual does not mentioned to drain the ATF for replacement of the pressure switch; so, probably little if any will drain out during switch replacement. You don't want to start the car with the switch removed from the transmission. When replacing switch, use a new crush washer.
margarette
Jul 16, 2013 08:26 AM
mjc
Jun 28, 2012 08:58 PM
lunkerv16
Aug 1, 2008 05:02 AM
Catman55
Apr 29, 2006 06:51 PM
