PA 99 Turbo Miata 49k
SOLD
For Sale -- 1999 Miata -- 49,000 miles / $10,500
$10k w/o hardtop
This car is extensively modified to go, turn, and stop with equal speed and precision.
Powertrain
Flyin' Miata turbo kit, 9 psi with piggyback ECU control and intercooler
Flyin' Miata clutch kit with lightened flywheel, heavy duty disc and pressure plate
Full-length 2.5-inch stainless steel exhaust with dual tips
Double-capacity aluminum radiator
Approximately 275 horsepower, vehicle weight 2,500 lbs
Suspension
Tein Flex coil-over kit with adjustments for ride height, spring preload and damping rate
Flyin' Miata anti-roll bars
Polyurethane suspension bushings
Front shock tower brace
Brakes
Goodwin Racing big brake kit
Two-piece aluminum hub rotors, 11-inch front, 10-inch rear
Wilwood 4-piston forged monoblock calipers front, stock rear with custom brackets
Street pads with low dust and no noise
Wheels & tires
Rota Circuit 8, 15-inch alloy wheels, 12lbs
Toyo T1-S
Interior
White gauge faces
Additional gauges -- oil pressure, water temp, boost
Voodoo titanium shift **** and brake handle
Hard Dog roll bar with fitted pad, top function remains unchanged
Exterior
Mazda Miata hardtop with rear defroster, headliner, and side striker latches
Moss Motors chrome fuel lid
Go Miata stainless steel grill
The car was purchased by the previous owner in 2002 with 15,000 miles in stock form. All listed modifications were then added. The car is completely sorted and reliable for everyday street driving; just at a much faster rate! The exhaust is beefy but not loud. Body and top are in excellent condition and the car has never been hit. The timing belt and water pump was just replaced. I have all the service records and all the modification records as well. The title is clear of liens and in hand. This car is ready to sell!
Open to trades. Must have clean title. No automatics or rustbuckets.
Also, I accept bullion and cryptos.
$10k w/o hardtop
Powertrain
Suspension
Brakes
Wheels & tires
Toyo T1-S
Interior
White gauge faces
Exterior
CHEETAH
Dec 4, 2002 06:41 AM
