09 si won't start without starting fluid
Old Jul 13, 2014 | 09:53 PM
Eldubsbro1's Avatar
Default 09 si won't start without starting fluid
Still having the same problem with the car it needs starting fluid to idle properly and run . It gets fuel pressure at the ktuned fuel rail. It gets spark. The fuel lines are brand new.has brand new oem injectors. New speak plugs. The fuel pump was tested out of the car and works fine. The car throw a p1077 code which is imrc valve is stuck open. Really still need y'all's help!!
Does anyone know what the line is that's open in the picture provided is and where it's supposed to go as well ? Really need your help!
Old Jul 13, 2014 | 09:54 PM
Eldubsbro1's Avatar
Default Re: 09 si won't start without starting fluid
Here's a closer pic
Eldubsbro1
Jun 16, 2014 11:13 PM
MastaFlyMason
May 18, 2013 09:32 AM
00Civik
13
Aug 22, 2011 06:37 PM
thepaintedman48
Honda Motorcycles
Jun 7, 2007 04:15 PM
