coolant temp sensor problems.
Old Jul 13, 2014 | 11:35 AM
707Honda's Avatar
Default coolant temp sensor problems.
Hello everyone, Ive been having a fustrating problem with this sensor. Heres the problem. The temp guage always goes to max hot as soon as key is on. I replaced the sensor since it was only 8 bucks and still have same problem. I can leave the sensor out of the head and hook up the yellow/green wire and my guage reads full cold with the sensor just hanging there. But as soon as I bolt the sensor to my head or even touch it to my head my guage reads full hot. Do I have grounding issues or wiring problems cuz it's just a single ground wire running the damn thing right. 90 crx d15b2
Old Jul 13, 2014 | 11:48 AM
F22Master's Avatar
Default Re: coolant temp sensor problems.
Sounds like a short in the wiring. Check the continuity of the wire from the sensor all the way to the gauge cluster.
Old Jul 13, 2014 | 05:15 PM
707Honda's Avatar
Thanks for the quick reply. My yellow/green wire is 88.3 ohms with key off and is puttin out 12v with key on. I recently had to replace most of the lights in the guage cluster guess Ill start there.
710dabber
Nov 5, 2015 12:36 PM
93del
Dec 19, 2010 09:49 AM
byronl
Feb 17, 2007 03:26 PM
Twistedframe
Feb 5, 2004 07:53 AM
erniecars
May 20, 2002 12:52 PM
