Best turbo cams 4 LS motors
Old Oct 31, 2002 | 05:02 AM
MIKES's Avatar
Default Best turbo cams 4 LS motors
I have the JG 1001in my car and I am very pleased with the performance, but my idle is too inconsistant. What are the best cams for a LS motor with head work, strong bottom end, Zdyne Gold ecu, big injectors, skunk2 intake manifold, and a t3t40e turbo? I have seen alot of vtec cam questions for turbo but not enough info on LS cams. Is the stock cams the best for turbo applications? My buddy told me to put in my stock cams because he thinks it will run perform better. Whats your take on this guys. I would like to start a informative thread for the LS guys and myself. Post cam charts if you have them and dyno numbers. My goal is to get my 2860 pound Integra with me in it into the low 12's high 11's. But must remain streetable above all else.
Old Oct 31, 2002 | 09:26 AM
MIKES's Avatar
Default Re: Best turbo cams 4 LS motors (MIKES)
up
Old Oct 31, 2002 | 09:54 AM
lazerus's Avatar
any cam with more more lift, equal duration and NO overlap should help make more power.
i'm unfamiliar with honda/acura cams, but i'm sure someone here is....
edit: Equal duration, oops =]
[Modified by lazerus, 9:52 PM 10/31/2002]
Old Oct 31, 2002 | 10:12 AM
DIRep972's Avatar
Smarter than you
i think rocket and 2kteg are developing some new turbo cams for the LS, should be interesting.
Old Oct 31, 2002 | 11:00 AM
Etylorcen's Avatar
Default Re: Best turbo cams 4 LS motors (DIRep972)
For a turbo cam you should be looking for more lift LESS duration. More duration would mean more overlap. So far crower has been the best ls turbo cam i've heard about.
Old Oct 31, 2002 | 01:30 PM
GEN2TEG's Avatar
Just curious as to how much power your putting down?
Nice pics by the way, sharp looking teg.
As for cams i say stick with your ls cams.
gen2teg
Old Oct 31, 2002 | 02:40 PM
SIK IN DA HED's Avatar
New User
Default Re: Best turbo cams 4 LS motors (Etylorcen)
really? i thought stock cams were the best for ls turbo so far.
Old Oct 31, 2002 | 03:16 PM
DIRep972's Avatar
Smarter than you
there is a HUUUUUUUUUGE market for an LS turbo cam. If someone would develop a cam that would allow the LS to make power to 8k w/ boost levels from 10-20psi it would sell like hot cakes. I know there are soooooo many LS guys who would buy the turbo cam w/ valvesprings & retainers.. there doesnt seem to any proven cams out for the LS right now, the demand is there, just not the supply.
Old Oct 31, 2002 | 03:32 PM
touringteg's Avatar
I would buy one
I'm also looking for good cams for a turbo LS
Old Oct 31, 2002 | 05:08 PM
johnisenglish's Avatar
Default Re: Best turbo cams 4 LS motors (touringteg)
I'd take one (well, two) too
[Modified by johnisenglish, 6:08 PM 10/31/2002]
Old Oct 31, 2002 | 05:12 PM
DIRep972's Avatar
Smarter than you
Default Re: Best turbo cams 4 LS motors (johnisenglish)
group buy?
Old Oct 31, 2002 | 06:25 PM
Blaze45's Avatar
Brrraaaap!
yeah rocket needs to get rippin w/ those cams Id like some... once Im turbo'd of course....
Blaze
Old Oct 31, 2002 | 07:09 PM
2K_TEG's Avatar
Default Re: Best turbo cams 4 LS motors (Blaze45)
The LS cams are designed, it is just a matter of getting them made, testing them, tuning cars with them, etc. Basically the easy part is done, BUT most of the work still needs to be done.
HT will be the first to hear about their release, and there will be a monster GB for them after they are released. Most likely I will be hosting the GB, answering questions, etc.
Right now that is all the info I have. Rocket is working hard to get the cams, springs retainers, produced, and tested. I am taking on some extra work to free up his time, and we are collaborating on some things.
I do not have an ETA or an estimated price. These things will come in the coming weeks, months. As you know all sort of cams from turbo D16 to NA B18C cams are in the works and they should all be released at the same time.
Old Oct 31, 2002 | 09:18 PM
Speed PHreak's Avatar
Default Re: Best turbo cams 4 LS motors (2K_TEG)
Yup, I talked to rocket about a week ago about his turbo cams for the LS. They seem to be close to the specs of the custom Web Cams i'm running. It'll be interesting to see what kinda dyno numbers you guys can get out of some turbo LS cams.
Just a side note, the Crower turbo cams seem way to peaky. Sure they've got lots of lift (about 11.9mm), but the duration is almost stock-ish. That makes the cams have a VERY steep slope with not much pad at the top of the lobe. To me that doesn't seem like a very valve-train healthy combo. From what I conversed with Rocket, the specs he's got coming for his cams would seem to share the same line of thinking. We'll see how it all works out for you guys though.............I've already got my turbo cams
[Modified by Speed PHreak, 1:19 AM 11/1/2002]
Old Nov 1, 2002 | 12:08 PM
Etylorcen's Avatar
Default Re: Best turbo cams 4 LS motors (dlplayboy)
The stock ls cams arent that great. If you look at any dyno you can see how it has a good midrange but in the top end the torque just completely drops off.
Old Nov 1, 2002 | 12:16 PM
DIRep972's Avatar
Smarter than you
Default Re: Best turbo cams 4 LS motors (Speed PHreak)
do u care to share the specs on ur cams? and why u chose those specs?
Old Nov 1, 2002 | 12:24 PM
Midwestrider's Avatar
I would like to know too..
Old Feb 20, 2003 | 09:37 PM
Armaan's Avatar
Default Re: Best turbo cams 4 LS motors (Midwestrider)
Are the Turbo LS cams by Rocket out yet? My motor is built...all I need is cams!
bigislandc2
Aug 10, 2006 01:56 PM
mrDFWmechanic
Oct 19, 2004 11:16 AM
Silverhatch
Nov 26, 2003 02:06 PM
CBR600OnTop
Jan 14, 2003 07:05 PM
LshatchTurbo
Sep 11, 2001 06:20 PM
