95 Civic/D15Z1 - Oxygen sensor heater problem
Old Jul 12, 2014 | 11:53 PM
hayllone's Avatar
Default 95 Civic/D15Z1 - Oxygen sensor heater problem
Hello guys, thats my first post but sadly, its because a problem with my Civic, so, the car is 95 Civic hatch, engine: d15z1
Its with that 5 wire o2 sensor... So, i have an error code 41 showing, which means: Oxygen sensor heater - circuit malfunction
I'm using Autodata software, and did the suggested testing of the sensor resistance between the pins and it is ok.
Then i proceeded to a test of the voltage which comes to the o2 sensor, and in autodata its written that it should be equal to the batery voltage (around 12-13 V), but sadly i have there around 3-5V ...
Any ideas what can be the reason to do not have enough voltage, and where to search the problem... Thanks!
Old Jul 13, 2014 | 04:13 AM
roy ilkenhans's Avatar
Default Re: Oxygen sensor heater problem
the connector if not you will have to trace it back to the pcm/ecm
Old Jul 13, 2014 | 07:09 AM
Former User's Avatar
There are 2 voltage tests, one using the Blk wire as ground and the other using the engine/chassis as ground. What were the voltage readings for each test?
Old Jul 13, 2014 | 02:14 PM
hayllone's Avatar
Default Re: 95 Civic/D15Z1 - Oxygen sensor heater problem
Both were equal, exactly 6.8 V , while i got 12.33 on the batery.
I checked the wires, and i found the main one, which is comming from the inside of the car, that is the wire on which we do this voltage test, i did the test again (before any connector) when using the engine as a base, and again 6.8V, this fact makes me sad... the problem maybe is even before the wire start... i dont have idea.. :/ (btw today my o2 sensor was tested on another d15z1 and it is working)
Tomorrow i will post a pictures of the whole path of the wire
Old Jul 13, 2014 | 02:22 PM
If you follow the service manual instructions, it clearly tells you that the Blk ground wire is bad.
Old Jul 13, 2014 | 03:40 PM
eghatch9295's Avatar
Stancetard Hate Monger
zing
Old Jul 14, 2014 | 12:57 AM
hayllone's Avatar
Ok, i followed the manual and - result is Open in the BLK cabel...
But all the wires are so hard to be reached and check where is that problem with the BLK cabel.
So, what this black should be, a ground? And if so, can I just connect that black to a ground, thanks!
P.S : I see that g101 is located at termostath body, and when i connect the YWL/BLK to that, i can see that there is again ~7V , so i dont see a reason that the BLK to be opened..
Old Jul 14, 2014 | 04:14 AM
jlk16188's Avatar
I had the same issue with my VX. I cut off the ground wire just after the connector in the harness close to the O2 sensor and ran a new ground to the thermostat housing ground location instead of messing with the factory harness in that tight location. Its been working flawlessly for 30K miles now.
Old Jul 14, 2014 | 04:32 AM
hayllone's Avatar
Ok, i'm heading to the car now and will give a try to that solution, I will let you know if that works (i hope! ) Thanks.
Old Jul 14, 2014 | 05:26 AM
hayllone's Avatar
Result: Fail.
What i did is, I did a new ground connection, from the harness to the termostat body (the new connection is very near to the sensor.
And again, when i check the V while engine is in idle, between YWL/BLk and BLK , it shows ~7 , ~7.3 V....
Old Jul 14, 2014 | 05:29 AM
The ECU MUST control ground at the black wire. Otherwise code 41 will be thrown.
Old Jul 14, 2014 | 05:35 AM
hayllone's Avatar
Ok Ron, I will re-connect the original cables, but any usefull idea how to trace down easier :?
And also, does g101 = termostat body.
Because in the guide is written to check connection between the sensor and that g101, and if g101 is the termostat, to where that black cable is connected before it goes to the LAF, to be controled from the ECU, thanks!
Old Jul 14, 2014 | 05:40 AM
Edit - My last post was in error. The black wire does indeed ground on the thermostat housing (G101). Run a new wire from the FAF connector directly to G101.
Old Jul 14, 2014 | 05:47 AM
hayllone's Avatar
Thats what i did, and then, while engine is in idle, I've tested the YWL/BLK and BLK wires, and again 7V, i did this test while the LAF is disconnected
Old Jul 14, 2014 | 05:48 AM
Thats what i did
Provide details and pictures.
Old Jul 14, 2014 | 05:52 AM
Result: Fail.
What was voltage to body ground?
Old Jul 14, 2014 | 05:57 AM
hayllone's Avatar
Again 7V , going down to take pictures
Edit. Here are the images:
Old Jul 14, 2014 | 06:29 AM
The wire splicing and G101 connection jobs are less than optimal and you also need to consider that the open may be at the pin inside the LAF connector, which your splice does not bypass.
Old Jul 14, 2014 | 06:34 AM
hayllone's Avatar
what this means: "The wire splicing and G101 connection jobs are less than optimal" what i need to change
Edit: Also, the open cant be in a connector, because i do tested and YWL/BLK to the new orange, and again 7V
Old Jul 14, 2014 | 06:38 AM
tony_2018's Avatar
Fish Twig
I think he meant the brown rectangle connector near the ecu?
Old Jul 14, 2014 | 06:47 AM
hayllone's Avatar
So far what are the results from the tests:
YWL/BLK - Body Ground - 7V
YWL/BLK - BLK (from the harness) - 7V
YWL/BLK - Orange (my new wire) - 7V (no matter where i test: on the connector or directly on the cable)
Old Jul 14, 2014 | 01:03 PM
hayllone's Avatar
Any thoughts? I dont know what to check anymore.. :/
Old Aug 12, 2014 | 02:50 AM
hayllone's Avatar
Still did not found any solution
Any other ideas, what to check :/ Thanks!
Old Sep 9, 2014 | 03:40 AM
hayllone's Avatar
I'm currently wondering if it can be some relay which is causing that problem..
Old Sep 29, 2014 | 06:58 AM
hayllone's Avatar
