Need quick response to Si camshaft
Old Jul 12, 2014 | 04:01 PM
Ef4doorwagon's Avatar
Default Need quick response to Si camshaft
Nevermind
Old Jul 12, 2014 | 05:28 PM
bEEsKnEEs's Avatar
Default Re: Need quick response to Si camshaft
to tell if its an si im not sure, i would measure lift. Also the d16a6 had that different timing mark around 7 o'clock on the cam gear to the inner timing cover.
File Type: pdf
Old Jul 14, 2014 | 12:21 PM
xprometheusx's Avatar
um fyi 89-91 DX/LX/Si all have the exact same camshaft. only the 88's had different as well as the ZC cams are the only ones that are timed more aggressive on the actuel cam. howerever the SI runs a different came gear wich needs to be transfered if you wish to run the si ECU. if you have a 1.5 you have to transfer the 1.5 camgear to the 1.6 cam to keep the timing the same the cam gear is the only thing that is actuelly different and results in different timing.
efnick
Sep 29, 2007 07:52 PM
BlueRex1020
16
Dec 2, 2006 12:11 PM
CRXracer88
Jun 30, 2004 08:05 AM
subgeniusdude
Aug 19, 2003 11:33 PM
dgonzals
Jul 7, 2003 05:28 PM
