tuner 2 or bc spec3+ for itr swap
Old Jul 12, 2014 | 10:44 AM
dc4teg95's Avatar
Default tuner 2 or bc spec3+ for itr swap
I got a usdm b18c5 and looking to upgrade to tuner 2 cams. Would these be ok for the stock 10.6:1 cr or would something smaller like buddy club spec3+ cams be more ideal? Car is mainly a street car. Only mods are the basic bolt one. Toda rep header, greddy evo2 cat back and 3 inch sri with aem dry flow filter
Old Jul 12, 2014 | 01:10 PM
TheShodan's Avatar
Moderator
Default Re: tuner 2 or bc spec3+ for itr swap
It'd stick with the Buddy Club Spec 3+ for that type of build. Mainly a street warrior with that type of compression would do best in the midrange that you're looking for.
I loved the GReddy Evo2 Exhaust. one of the best performing and sounding exhausts around. unfortunately, after 7 years, the resonator is a bit blown out, so I'm creating a different exhaust for a similar build. I think you'll like it those cams for your purpose.
Old Jul 12, 2014 | 02:14 PM
dc4teg95's Avatar
I loved the evo2 sound but same here I have had mine for 7 years as well and time has taken its toll. Doesn't help I have a small hole in the resonator. Wanted to try out the sp2 but its no longer available so I found a sp2 rep muffler made by tsudo I got from speed element that Ima try out on a extra axle back pipe I have. I was leaning towards the BC cams for the midrange. Not t looking for a street monster just a fun lil car.
Old Jul 12, 2014 | 06:22 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Tuner 2s will make more peak power, but the BC3+ will be faster on the street.
I'd use the Buddy Clubs
Old Jul 12, 2014 | 09:42 PM
OMG's Avatar
OMG
what is your goal
Old Jul 12, 2014 | 10:11 PM
UncleD's Avatar
Old Jul 13, 2014 | 05:13 AM
dc4teg95's Avatar
Goal is to have a fun lil street car with usable power band. Not interested in having a all out monster. Drivability and reliability. I don't drive it everyday anymore but when I do I like just getting in and turn key n go. No tweaking things.
Old Jul 13, 2014 | 07:21 AM
TheShodan's Avatar
Moderator
I would have just swapped resonators and kept everything else
Old Jul 13, 2014 | 08:02 AM
dc4teg95's Avatar
Well I do still need to do something with the resonator as far as the hole goes. Either weld it or replace it
Also would rdx injectors be ok to use after cam install
Old Jul 13, 2014 | 04:17 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
They'd be great, if you're aware of all the work that goes into running them as in injector hats, manifold modification, tuning etc
Old Jul 13, 2014 | 05:55 PM
blackeg's Avatar
what springs and retainers are you going to use?
Old Jul 13, 2014 | 06:49 PM
^^^X2.
OP hasn't mentioned it, not sure he's aware he will need upgraded valvetrain
Old Jul 13, 2014 | 08:18 PM
OMG's Avatar
OMG
Rocket Motorsports M22KE cams with Rocket SL springs
good to 11,000 rpms
Old Jul 13, 2014 | 08:52 PM
11,000 rpms. Usable powerband. Street car. Hahahaha
Old Jul 13, 2014 | 09:49 PM
OMG's Avatar
OMG
the motor won't make power there but good to know it can handle in case of mechanical over-rev (e.g. mis-shifting into 2nd gear when going from 3rd to 4th)
Old Jul 14, 2014 | 05:55 AM
dc4teg95's Avatar
I was under the impression the stock itr valve train would handle the spec 3+ cams as long as I stayed with in the stock rev range which on a c5 is 8400 or 8500. My s100 has just a base map itr map with rev limit at 8500 and from what I have read the buddy clubs start to fall in power round 8-8500. But I would mostly likely go with buddy club springs and itr retainers
Old Jul 14, 2014 | 05:59 AM
TheShodan's Avatar
Moderator
The Buddy Club Springs and retainers do quite well. I even use those on one of my TODA RACING builds. you're fine getting those over even Supertech or others.
Best to match when you can.
Old Jul 14, 2014 | 07:51 AM
PJ_Sir's Avatar
good to 11,000 rpms
I bought these for my ITR, waiting to see how much will improve!
Old Jul 14, 2014 | 08:09 AM
blackeg's Avatar
it would be a bit sketchy to run the bc3+ on itr valvetrain. its just a few hundred more bucks and terrific peace of mind. i think the only cam id really run on itr valvetrain besides itrs are tuner1's . id believe you have to look more at the lift of the cam to see what kind of spring you need.
what about the rsx-s oe retainers do you guys recommend them for this type of build to keep costs lower
Old Jul 14, 2014 | 11:13 AM
Cams that run to 11,000 rpm are designed to make power there and are not for the street. Try running those rocket springs all the time at street rpms...
Old Jul 14, 2014 | 11:55 AM
2LEM1's Avatar
I like to party
Community Builder
When Buddy Club was asked specifically if you can run BC3+ cams on ITR valvetrain, here was their response:
Hello James,
It's highly recommended, but not necessary.
Jerry Roberts
Buddy Club USA
AAI Motorsports
P 909.923.9188
F 909.923.9108
AIM BuddyClubJerry
Take that for what you will.
Old Jul 14, 2014 | 12:24 PM
UncleD's Avatar
I am beginning to think that I've had the wrong impression about Buddy Club for a looong time now.
Rocket brain washed me as a dealer, but I've seen comments here and there over time and it's made me think that they actually aren't as bad as Robert made them out to be.
I think he felt threatened by the BC4 cam. He told me that those were a Toda B primary with Jun3 vtec. Has anyone else heard this rumor?
Old Jul 14, 2014 | 02:49 PM
dc4teg95's Avatar
I do like for everything to match if possible for warranty issues. I see password jdm has head package that comes with the cams v/t and gears for 950. Guess while I'm at it get their head gasket for alight bump in compression or should just stick to oem hg?
Old Jul 14, 2014 | 03:31 PM
I don't think a thinner head gasket would hurt, but then again, I don't know how aggressive those cams are. But it doesn't sound like they're too aggressive. I think your only concern would be P2V clearance, but if its a street cam, you shouldn't have any trouble at all
Old Jul 14, 2014 | 03:38 PM
In the 90's, I hear BuddyClub used to be the shiz. That was when it was still actually JDM. It has since been sold to some Taiwanese company that has now owned it for years. I don't know that any of the product designs (like cams) from back then have changed, although being made in Taiwan certainly gives the impression that they are lower quality now.
I don't think Buddy Club was ever a knockoff company, I mean they used to be heavily involved in japanese racing circuits. I mean, they designed one of the most popular body kits of all time! I don't imagine that their cam was a spinoff, but who would really know unless they measured
