Why does my car still smoke? i changed the head gasket
Old Jul 11, 2014 | 06:53 AM
Cole LaFleur's Avatar
Default Why does my car still smoke? i changed the head gasket
I have a 1998 honda civic ex 1.6 sohc. and i recently changed the head gasket.. its a grayish white smoke.. and i did everything to make sure it wouldnt smoke... i took the head to a shop and they checked it out and told me it was good. (they also cleaned the gasket surface) so no problems there... i checked everything over.. went to torque specs.. got all of that done to spec and seq. And ive ran out of ideas on what it could be.... its still smoking.. and now its doing this idle thing.. it will idle high (3k rpm) then it will stark doing this missing idle.. till i gas it up.... do i need to do timing? valve adjustments? i know about the cat problem but i drove the car around my town (30 miles) and it wont stop smoking .. i also put down cardboard under the exhaust tip.... and it looks like its shooting out condensation with black stuff also... soo maybe i need to drive it more? help me please x.x
Old Jul 11, 2014 | 07:08 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Why does my car still smoke? i changed the head gasket
Maybe the block surface was uneven.
Old Jul 11, 2014 | 07:18 AM
so basically this renders my engine useless?
Old Jul 11, 2014 | 07:27 AM
The Grumpiest
Backstory please. Was the car overheated often?
Old Jul 11, 2014 | 08:18 AM
as far as i know.. the car was over heated once (and from what i was told it wasnt off the temp gauge it was still around the middle) ... then the guy never drove it again because he was afraid the car was going to die... so he bought a new civic and wanted to sell this one.. so i bought it.. and it had oil in the radiator (not a lot just about a cap full of oil for the whole radiator... which i flushed it and drove it.. ) then it did some idle **** where i had to swap out a bunch of sensors and had to change the temp gauge a bunch of bs... but thats all i know about it.. i drove then this from the guys house to mine and it ran fine.. till i stopped then the thing would idle low .. but i fixed that . and now it idles high... and smokes.. and misfires .. and id rather not have to put a new engine in this thing..
Old Jul 11, 2014 | 08:24 AM
The Grumpiest
Compression test it.
Old Jul 11, 2014 | 08:30 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Maybe bad spark plug seal, or valve seal.. or bent valve?
Old Jul 11, 2014 | 09:04 AM
i have to do the compression test but i know the spark plugs and the spark plug seals are all new ..
flash69
Engine Management and Tuning
Nov 23, 2008 12:25 PM
westside49block
11
Feb 2, 2008 09:32 PM
Frost_1097
Jun 18, 2007 07:21 PM
KeithGSR
May 3, 2005 06:11 PM
SikofFalln
Dec 13, 2001 08:35 PM
