91 civic rear disc conversion question
I got the rear trailing arms off a crx si. The hubs look a little bit beat. I can't find rear hubs to save my life. AutoZone, Napa no body. My question is are the hubs off a DA able to be pressed onto the crx arms. I hear it is the same but the part number is not the same at AutoZone. I got a set to try but the backside of the bearing is still stuck on the shaft of the trailing arm. from the back it does look about the same diameter.also do I need the back of the bearing pressed off or should I try to heat it up and expand the metal Any help is appreciated.
52370-SK7-A04 Acura Integra rear disc trailing arm (1990)
52370-SH3-G07 Honda CRX rear disc trailing arm (1991)
I'm not sure if the hubs will fit.
Why not get direct replacements?
42200-SX8-008 Rear Hub assembly CRX disc (1991)
$100 New from Majestic Honda online
http://www.hondaautomotiveparts.com/...EAR+BRAKE+DISK
System Name\Component : REAR BRAKE DISK
That is same style hub autozone try to give me if you look in between the lugs there's extra holes are all the way around it in between the lugs no area to screw rotor hub.
WHOA! You don't need those screws! It's for the machines to assemble the vehicles. The lug nuts will hold the rotor to the hub. Fact. Those screws are useless after the car comes off the line.
you learn something new everyday day . Freeman and others that tried to help out I appreciate it.
They are just assembly screws because the cars don't have wheels on them. haha. I never knew it until recently when I was worried because my car was missing both of them.
jacksonww
Oct 5, 2010 05:09 AM
asianflava
Dec 8, 2008 11:14 AM
wade
Suspension & Brakes
May 25, 2006 12:18 PM
