oversize bearing help!!!
Old Jul 9, 2014 | 04:07 PM
racereaper7's Avatar
Icon3 oversize bearing help!!!
got an eagle crankshaft (87.2) that has been turned down to 54.72 (mains). the stock size is 54.97 is the lowest.
so is there any way i can fix this?
talked to eagle and they said .25 oversize bearings might still be to much clearance but if i had a machine shop turn it down to .5 that i could use king bearings .5 undersize bearing and it should be fine
so im not sure what to do.
with the turning to .5 how much would i have the machine shop turn?
any help and advice would be great.
i cant really afford to get another cranksahft at this time since this is my second one
Old Jul 9, 2014 | 10:22 PM
OMG's Avatar
OMG
Default Re: oversize bearing help!!!
You need a +0.010" bearing. ACL makes those
Old Jul 10, 2014 | 03:10 AM
so the the .25mm acl would work?
i was not for sure since that would make up for the .25 under but would still need the amount to make up for the bearing would be on a normal crankshaft?
does anyone sell 2 bearings single?
Old Jul 10, 2014 | 12:19 PM
OMG THE GOGGLES's Avatar
IMHO, you could run an OEM crank and save some potential headaches. The stock cranks are impressive and never saw a need for an Eagle crank in an all motor application personally?
Old Jul 10, 2014 | 12:35 PM
OMG's Avatar
OMG
that should work, what does golden eagle say
Old Jul 10, 2014 | 12:38 PM
I would have used an oem one but mine was broken by my machine shop and a buddy had an eagle version that is the stock size but it ended up being turned
-it's hard to buy a used one because you don't know the history and I don't have a good machine shop around that I would trust to fix anything
Old Jul 10, 2014 | 02:56 PM
from eagle "ACL, Clevite, and King all have the .25mm undersize (thicker) bearings. My worry is: even at -.25mm, it still looks like there may be too much clearance. If so, you can have a machine shop turn it to .5mm under. I know King and Clevite both make .5mm undersize bearings. I don't know about ACL."
Old Jul 10, 2014 | 03:00 PM
i wish i could buy 2 just to try them out (.25mm).
the problem im in is that i really dont have a local shop (no one in town turns) that i could trust to do it
Old Jul 10, 2014 | 03:57 PM
OMG's Avatar
OMG
I have these, pm me
dustin_68f100
13
Jan 30, 2008 06:27 AM
Peter Brady onlyonweekndz
Nov 2, 2007 09:05 AM
johnls
Aug 4, 2007 10:47 PM
