Detune a Rsx Type S
Old Jul 9, 2014 | 08:21 AM
187Chor's Avatar
Default Detune a Rsx Type S
Is it possible to detune a type s so it runs on 87 octane??
Im not talking about swapping internals, just reflashing the ecu maybe
Old Jul 9, 2014 | 10:49 AM
doood's Avatar
been there done that
Default Re: Detune a Rsx Type S
Why?
If it's because you can't afford to fill up on premium, you should probably reconsider your priorities.
Old Jul 9, 2014 | 11:51 AM
Sonin Fury's Avatar
Originally Posted by doood
Why?
or consider a older civic/accord
Old Jul 9, 2014 | 05:58 PM
187Chor's Avatar
Is there anyone who can answer this?
Old Jul 10, 2014 | 05:39 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
yes you can retune for it.
Old Jul 10, 2014 | 09:06 AM
mustclime's Avatar
base motor swap........
Old Jul 10, 2014 | 09:17 AM
BWek's Avatar
the money you would Spend on retuning it would be a year or 2 in the difference in the price of gas
Old Jul 10, 2014 | 11:08 AM
SquidByrd's Avatar
Or maybe not drive the car as often can work in saving gas as well. You can also retune on e85. It's cheaper but might burn more. but hey, whatever works for you brother.
Old Jul 10, 2014 | 03:00 PM
Deetz's Avatar
Crazy Honda Guy
What a topic!! Detune a Type S? What's the point....that is what a non S is for
By switching a to base, you can use regular gas, plus get cheaper insurance. Sounds like you drive the wrong car
Old Jul 24, 2014 | 09:38 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Detuning will not lower the CR and will trash your FE....
Old Jul 24, 2014 | 10:00 AM
burnoutboy's Avatar
The Credible Hulk
Yo, I got a 92 Civic CX with a B18B1 swap in it. 87 all day long Monica. I'll throw in a pitbull puppy with no papers and drive to Niagra for a straight title swap? You game bro?
Old Jul 24, 2014 | 02:04 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Old Jul 25, 2014 | 02:35 AM
andoxviii's Avatar
You are driving the wrong car.
Your car requires 91 octane or higher because of its compression ratio. You can't just change software and expect to be able to run 87 octane. Even if you were to do that, it doesn't change your 11.0:1 compression ratio.
Old Jul 25, 2014 | 07:48 AM
187Chor's Avatar
Ok i had a b16b which uses high compression pistons so id pump 91 octane. I turboed it against all advice from everyone on here and was told id need a way higher octane than 91 to make it work. Surprise surpise it worked out just fine and when it was tuned to use 91 octane all that was required was that the ignition timing was retarded slightly.
so shouldnt that work in this scenario as well?
Id appreciate answers from people who know what their talking about i dont wanna hear **** talk or opinion
Old Jul 25, 2014 | 11:04 AM
Axix24's Avatar
Hondata kpro can allow you to run 87 with it. Or you could run k tuner and prolly pull a ton of ignition timing. Car will feel sluggish tho. Its only few bucks more!
MaGoodc2
31
Jan 19, 2013 06:10 PM
billedoc
55
Apr 14, 2006 11:58 AM
vnvracing
Apr 4, 2006 09:00 AM
01-0720
Mar 16, 2004 04:50 PM
ChuJai
Aug 23, 2001 07:13 AM
