need advice with air intake/battery mod
Old Jul 9, 2014 | 05:25 AM
skwigelf's Avatar
Icon2 need advice with air intake/battery mod
Okay so i'm rebuilding this civic from the inside out and im planning on putting a more heavy duty battery (deep cycle) under the hood for audio. Problem is, the battery needs 2 more inches clearance. I've decided to take the old intake out and put a performance, short barrel, in. The intake, starting from the throttle body,1.) has a small hose that bridges off into the engine, then following the hose, goes into the air filter box on the passenger side corner of the hood, and then drops down, turning into a plastic rectangular intake tube. The only thing i was worried about when planning this idea is the MAF sensor. I read up in my haynes and it says there is no MAF sensor... Is there another sensor along the length of the air intake that i'm not seeing? Or can i just take of the old and put on the new without the PCM acting up?
Old Jul 9, 2014 | 05:40 AM
whited's Avatar
CRX God
Default Re: need advice with air intake/battery mod
Have you thought about relocating your battery?
Old Jul 9, 2014 | 06:11 AM
Freemananana's Avatar
Alright!
You can remove the intake you have now. Just connect the existing line (circled in green) to the new intake (circled in green). You DO NOT have a MAF sensor. This tube is should be positive crank case ventilation or something like that. It may go to the PVC and to the black canister (charcoal filter) for emission reasons.
Does that help?
Old Jul 9, 2014 | 06:31 AM
skwigelf's Avatar
Originally Posted by Freemananana
Alright!
Does that help?
Helps alot, appreciate it. Im currently painting some trim and the wheels as well but as soon as i finish ill update you with the results
Old Jul 9, 2014 | 06:48 AM
You shouldn't have any issues! I'll keep an eye out incase you do run into something.
onda22
Sep 9, 2011 04:42 PM
MG-EP3
22
Sep 1, 2009 10:00 AM
integraGSR1
Mar 19, 2004 02:11 PM
mlitt
Dec 30, 2002 12:42 AM
2 litre EG
14
Nov 14, 2002 08:10 AM
