Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
I want to spend 2k - 2.5k USD on suspension, what setup?
Old Oct 30, 2002 | 11:40 PM
austrian type-R's Avatar
Default I want to spend 2k - 2.5k USD on suspension, what setup?
This is for an all out autoX car, Civic EG 6 with B18C5 swap, 190whp. Fully stripped interior, running slicks on the track. I must be able to adjust the dampers in rebound & pressur in installed condition with a special tool or srewdriver.
What is the best suspension for this car, what spring rates to go with.
hm, Zeal type S6, Fightex, Tein? I need experince from an PRO who drives an EG6 and has an all out AutoX suspension. THANKS ALOT!!!!!!
Old Oct 31, 2002 | 02:26 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: I want to spend 2k - 2.5k USD on suspension, what setup? (austrian type-R)
I have the same vehicle setup, with RG coilovers (racing gear). I think list is about $2,400-$2,500 usd. You get your choice of spring rates, and the shocks have a adj lower portion. great great shocks. unfortuneatley, not too many people know about them.
Old Oct 31, 2002 | 08:18 AM
RineRacing's Avatar
I would look for a suspension system that has the following:
1. A least 1 way adjustable shock
2. Adjustable spring perch
3. Adjustable shock body length
4. Custom spring rates
5. A local service center/shop that can revalve them in a timely manner.
6. (Optional) Lightweight aluminum construction
There are more trick features that you could find in some shocks (i.e. inverted mounting, 3 way shocks, remote reservoir...) but for autocrossing the above mentioned items should be enough.
Old Oct 31, 2002 | 08:34 AM
Steve91's Avatar
My vote would be Advanced Design double adjustables. They go for $1600/set plus $220 more for springs.
www.advance-design.com
Old Oct 31, 2002 | 11:26 AM
owen_the_soyboy's Avatar
Default Re: I want to spend 2k - 2.5k USD on suspension, what setup? (Steve91)
Old Oct 31, 2002 | 01:36 PM
Frito's Avatar
ask here.... http://www.rcrewracing.com
They can get you the susp you're looking for and have tested different setups.
HTH
Francisco
Bloody Hatch
Suspension & Brakes
Jun 22, 2012 08:05 PM
Understeer
Suspension & Brakes
Apr 27, 2006 07:00 AM
dmckrazy45
Jul 5, 2005 06:38 PM
itr1236
Mar 6, 2003 09:13 PM
spangler
May 24, 2002 05:55 PM
