99 Civic - where does this bracket go on the transmission?
Old Jul 7, 2014 | 04:13 PM
Kevins89notch's Avatar
Default 99 Civic - where does this bracket go on the transmission?
Is this where this gold bracket goes? 99 DX
I replaced the input shaft bearings, and it's been about 2 week since I removed everything. I went to seal up the trans a bit ago and freaked out when I was missing two bolts. I then looked back at a picture I took, and I only had 11 when I broke up the trans. I'm 99% certain this bracket holds the hard line for the clutch. I assume I fully removed the bracket early on during the removal as what I assume are the other two trans bolts were sitting in this bracket.
Old Jul 7, 2014 | 05:07 PM
andoxviii's Avatar
Default Re: Quick easy question
Does this help?
Click here to check out all 5 images on tiger's website:
http://www.jdmtigerjapanese.com/hond...ion-96-00.html
Old Jul 7, 2014 | 05:55 PM
78F350's Avatar
This almost helps...
Looks like #24 in the diagram:
www.hondapartsnow.com
STAY, RR. RELEASE PIPE
Old Jul 8, 2014 | 05:17 AM
Former User's Avatar
Default Re: 99 Civic - where does this bracket go on the transmission?
Thread titles must summarize the tech question. "Quick easy question" is not adequate. Please read the forum Rules sticky. Title edited.
Old Jul 8, 2014 | 05:40 PM
94EG8's Avatar
Seagull Management
Yes it goes where you thought it did, and yes it secures the clutch hardline.
olddohc
May 24, 2012 08:42 AM
DISMANTLERGSR
Jan 17, 2004 11:29 PM
