Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Odyssey Air Conditioner
Old Jul 7, 2014 | 01:21 PM
markusnjop's Avatar
Default 2007 Odyssey Air Conditioner
Please help: the air conditioner in my 2007 odyssey EX is not running consistently. The blower and control panel appears to work normally, but the cold air is off and on. It seems as if a jarring pothole will bring the cold air back on when it is out.
I read prior posts on the ac resistor, but this problem seemed different, as the cold air works well at times.
Help is much appreciated,
Mark
Old Jul 23, 2014 | 02:40 AM
chuckmcb's Avatar
Default Re: 2007 Odyssey Air Conditioner
Mark, my 2005 odyssey (Touring) just started doing the same things you described...intermittent cooling, then none, then cool for a while...now it seems dead. I had not noticed the "jarring effect you describe. Did you every get a fix on the problem.
chuckmcb
Old Jul 23, 2014 | 06:03 PM
WanaBeFaster's Avatar
check the a/c compressor to see if it rattles. if it does, the clutch, stator (field coil), and relay need to be replaced. check a/c pressures to see if refrigerant level is ok.
Old Jul 28, 2014 | 04:37 PM
chuckmcb's Avatar
Thanks...you were right on. turned out the compressor was dead so had to do a "Big-bucks" replacement of compressor, adsorbent, Freon and the rest. Probably paid too much ($1200) but got the same story from two shops, so facing a cross ****ry trip across the South the die was cast!
Thanks again for you advice.
ChuckMcB
Old Jul 28, 2014 | 04:40 PM
chuckmcb's Avatar
Thanks...you were right on. Hoped for a bad relay, but it turned out the compressor was dead so had to do a "Big-bucks" replacement of compressor, adsorbent, Freon and the rest. Probably paid too much ($1200) but got the same story from two shops, so facing a cross country trip across the South the die was cast!
ChuckMcB
Nytrious
Sep 5, 2013 02:32 AM
skate1968
Jun 27, 2007 03:58 PM
abeaujuin
May 9, 2004 08:18 PM
B18C1 '96 Coupe
10
Mar 9, 2003 12:01 PM
