Integra starts up and dies immediately
Old Jul 7, 2014 | 08:19 AM
slow_low_eddie's Avatar
Default Integra starts up and dies immediately
B18a1 high compression
I have searched and people have said fuel filter, fuel pump, main relay (which I doubt), etc. I'm here to ask.
Basically, randomly I will start my car, it idles up and drops right back down and dies. I try to keep it alive by giving it gas but doesn't do much. It dies. It will do the same thing maybe two more times and then bam, third time or so, I give it gas to be sure and it stays on. I noticed it does it after I go to a few places, shut off the car, get back in, turn on and do this quite a few times.
Anyone have any suggestions? I haven't changed fuel filter. I just wanted to know if there some troubleshooting I can do before I dish out money. I have a multimeter and tools.
Old Jul 7, 2014 | 08:39 AM
tamboo's Avatar
10 Year Member
Default Re: Integra starts up and dies immediately
ignition coil?
http://www.team-integra.net/forum/bl...eshooting.html
test plug wires, resistance must be below 25k lohms
Old Jul 11, 2014 | 08:40 PM
syvlvr's Avatar
When this happened to me, I was stumped. The tow guy showed me what it was: my ignition was so worn it wouldn't stay engaged, so the engine would die. He kept the key all the way turned like when you start the car, left it there, car stayed running. Once he let the key go to normal engine died. Got the new ignition assembly for something like $50 and back in the saddle.
This might not be your problem, but can't hurt to try it out.
Old Jul 11, 2014 | 09:16 PM
shotoutacc0rd's Avatar
You should regularly change your fuel filter, it is regular maintenance. Dont not change it.
Old Jul 12, 2014 | 12:42 PM
EF9ESCOBAR's Avatar
Its the Distributor. had the same problem now fixed!
Old Jul 16, 2014 | 08:12 PM
tony_2018's Avatar
Fish Twig
When do you change the fuel filter on a regular basis?
Old Jul 16, 2014 | 08:37 PM
spoolymcgee's Avatar
This was happening to me i did a tune up, an went away. Change fuel filter as well. I found a great tune up kit on rock auto for 89.00 It includes NGK Iridium spark plugs. Good little kit on the cheap.
15-30k is ideal for fuel filter
Old Jul 31, 2014 | 02:14 PM
Car started to do it again. I'm thinking maybe the ignition switch? Needs some cleaning?
viprcr1
24
Sep 8, 2006 12:26 PM
red92EG
Jan 16, 2006 07:59 PM
trianglegreg
Oct 26, 2005 03:47 PM
crxxrc
Feb 8, 2004 01:39 PM
dumbchild
17
Jul 30, 2002 07:25 PM
