b20vtec eg hatch build
hey HT iv been collecting parts slowly but surely for my build. its going to be a mild b20vtec with suspension brake and body astehtic upgrades. iv already been working on her of course. ill get pictures up as soon as i can of everything. right now i have a gutted eg with a b20b in it. heres the list of everything going to be done or has been done. constructive critsism is welcome but im not looking to build the fastest hatch. i want a fun maintainable 92 cx hatch. im also looking for people selling any items i still need. feel free to leave feed back and ill get pics up shortly. just got my computer back up and running.
*=parts have
engine parts
____________
b20b bottom end*
oem crank bearings *
weisco 10.5:1 comp pistons*
npr 84mm rings*
arp head studs*
arp connecting rod bolts*
b16a2 head (completly redone oem internals)*
steel braided fuel lines*
walboro 180 fuel pump*
275cc injectors*
skunk2 68mm throttle body*
stock b16a2 im for now*
no name aftermarket headers for now*
header heat wrap*
oem felpro gasket set
b16a2 cams*
p28chipped*
filled solid motor mounts*
blox tps*
blox fpr*
golden eagle connecting rods
brakes
_______
96ex front drilled and slotted rotors /ceramic pads(done)
94 integra rear disc conversion/ceramic pads(done)
goodridge steel braided lines (done)
suspension
___________
skunk2 coilovers
function 7 lca (done)
blox sway bar endlinks *
godspeed sway bar (rear)24mm
eibech front sway bar or itr
*=parts have
engine parts
____________
b20b bottom end*
npr 84mm rings*
arp head studs*
275cc injectors*
header heat wrap*
b16a2 cams*
p28chipped*
blox tps*
blox fpr*
brakes
_______
suspension
___________
skunk2 coilovers
