2002 Accord: Belt squealing when starting after replacement
I had a mechanic replace some belts on a 2002 Accord EX 4-cylinder. The mechanic told me the following belts are replaced:
After a few days I noticed when starting, sometimes I could hear squealing for a few seconds. After that initial squealing everything would be OK.
I took it to the mechanic and he did some belt adjustments. The squealing problem seemed to be fixed.
But now after a month, the problem came back. However, the squealing duration has significantly decreased, to less than half a second compared to around 3 seconds before the adjustments.
It doesn't always squeal when starting. It is more likely to happen when starting in cold weather.
I'm not very good with cars so I'd be very grateful if you guys could give me some advice. What's the cause of the squealing? Did my mechanic use the right belts? Did he install the belts correctly? Is it necessary to do more adjustments?
Thanks!
- Timing belt
- Balancer shaft belt
- Serpentine Belt
- Power steering belt
- Water pump
Thanks!
Is the AC on when it squeels? Maybe the Ac or the alternator betl, probably not a big deal, he might have used a cheap belt.
Perhaps if the belt was originally tensioned to spec it may not squeal even after a few days of engine running since new belts stretch a bit a few miles after installation, if the new belt was originally a little loose than it should have been, it's going to squeal after a few miles, no doubt.
On the longest side of any serpentine belt, in the very middle of that side, if you can twist it more than 90 degrees the belt is too loose. So check it.
+1
techsupport
Mar 29, 2017 08:43 PM
aznromeo4u
Feb 18, 2015 07:51 PM
famfive
Jul 25, 2010 08:29 AM
