Eg crank but no fire up
Hi i have an 93 Civic vx I could use a little technical help today-if anyone might be able to provide it? My car crank but doesn't start up I replace two dizzy , got another ecu check all fuse all dash lights and sounds working, will push start but wont jump?? but still wont turn over-any suggestions?? Thanks?
with an engine not starting, start with the 3 basic thing's, air/fuel/spark.
you said you replaced dizzy, were they new or used?
have you checked plugs and wires and are you actually getting a spark? ( you saying you replaced the dizzy, did you put the spark plug wires on correctly? 1-3-4-2)
are you getting fuel?
think you should check these things first
Yeah the order is correct
31
42
I was getting spark & fuel it start up one time and when I was putting everything back it just die out and me now I'm getting no spark and yes it's a new dizzy
31
42
re-check your dizzy connections, re-check everything!! including grounds. try your old dizzy.
so it started before. and now it does not start after you put it back together. so to me this says you did something wrong.
try your old dizzy, double check your connections, double check your spark plug wires and spark plugs. everything you did go backwards in thought about what you did, possible you missed something.
I have seen spark issue where the dizzy end of the spark plugs were not on all the way making no connection. i doubt that is the issue but check it anyway on both the spark plug and dizzy end.
another possibility, if you were getting spark with your old dizzy, put the old one back on. how come you put a new one on in the first place if it was working before?
it had spark before but now it doesnt i change it b/c i though the dizzy was bad .
could it be the fuel pump ? making the car not running ? all my wire and spark plug are good i even try my spoon spark plug wire no go . new spark plugs .
thought you just said you were not getting spark, and in your previous post you said you were getting fuel. you need to read what is posted here, im willing to help and im sure other a\re to but if you are not going to listen there is no point.
if you old dizzy worked put it back and and confirm you are getting spark. i do not understand why you would change you dizzy if you had spark to a new dizzy that is not giving you spark....
what you are doing is creating more problems.
no pay attention
1. confirm you are getting spark, if not,put your old dizzy back on. and check if you are getting spark
2. confirm you are getting proper fuel delivery.
this is harder to help you because your posts are all over the place and dont make sense. you are saying two different things that contradict themselves.
no pay attention
im sorry i put the old dizzy back on but the spark is somewhat weak its not enough juice to power it up i think gotta check all my wiring with the volt meter .. i really appriecatian your help tho i just need my car running soon thats why im all over the place .
to confirm if im gettin fuel just turn the key and listern for the fuel to come in right ?
that is one way, personally what i do is i take the fuel line off of the fuel rail and have some one prime and turn the key for a second that will let you know you are getting fuel forsure
and
if the spark is weak in the old dizzy, it could be due to the ignition coil inside the dizzy. easy replacement if that is the case.
although it is weird why the new dizzy would have no spark assuming it was installed correctly or is a lemon of course.
post up though if you are getting fuel delivery and see if you can figuire out if the new dizzy will work forsure and do an ign coil test.
gas tank is not empty is it?
and
No spark now idk what to do ..no point in putting a new coil if I have a new dizzy and it still doesn't fire up ima have to get a mechanic to check out my car now guys ..
if you do not want to listen then don't expect anyone to help.
with how much a mechanic is going to cost you i can guarantee you could probably do it yourself. if you are going to be arrogant to wisdom and knowledge given to you, expect to pay the price.
re-read the thread, go over the list of things to try, go any try them, report back what you did and what the outcome was from them.
if not good luck to you
well you have not reported trying any of the ideas posted to help you.
http://www.clubcivic.com/board/showt...67#post3400667
REDEM1FTW
18
Nov 6, 2010 06:08 AM
fooboo
May 22, 2010 01:53 PM
SilverGT
Dec 2, 2006 03:12 PM
