NY 1992 Civic H22A4 Swapped 88K miles
FOR SALE: H22A4 SWAP'D 1992 HONDA CIVIC LX MANUAL
suspension from an acura integra, all brand new parts with matching CV shafts
springs cut 1.5"
Completely gutted interior except door panels/ABC Pillar panels
Motor is from 2000 honda prelude/transmission (60,000mi or so)
OBD1 P28 Mugen chipped ECU
New ARP 340LPH Stealth (factory location) fuel pump installed
New fuel pump relay/filter
New refurbished starter
New dizzy/seal set
Mr gasket translucent orange dizzy cap/rotor
New slave cylinder/fresh fluid
fresh penzoil 15w40 tranny fluid
Solid motor mounts with poly inserts (car vibrates quite a bit)
F/R upper strut tower bars
Ported/Polished TB
EGR Blockoff (emissions non existant)
4-2-1 Header/Catless test pipe full 2.25" exhaust Straight pipe to back
New driver front wheel studs
Blue rota D2 wheels
New front 10/32nd tread sumic tires
rear tires 4/32nd goodyears
new TPS sensor/harness/calibrated (800 idle when warm)
New Front calipers/pads rotors
New rear drums/cleaned/adjusted
now for the needs/problems:
-need LF fender
-check engine light on
-Vtec solenoid leaking alittle bit
-MINOR rust around quarter panels
text (716)997-5968
Car is off the road so no test drives, bring cash and trailer
3,200$!
springs cut 1.5"
New dizzy/seal set
Ported/Polished TB
Blue rota D2 wheels
-need LF fender
text (716)997-5968
3,200$!
