92 accord wheel alignment specifications
Old Jul 3, 2014 | 03:38 PM
afnan's Avatar
Default 92 accord wheel alignment specifications
I am going to align the wheels of car and wanted to know if anyone has specifications for camber, caster and toe for 92 accord
Old Jul 3, 2014 | 09:05 PM
forward's Avatar
Default Re: 92 accord wheel alignment specifications
They are listed in the factory service manual, which you can download here: http://www.manualslib.com/manual/464...da-Accord.html
...or skip to page 43 in the viewer.
Old Jul 3, 2014 | 11:30 PM
afnan's Avatar
Thank you. How to understand these, why are numbers in bracket what do they represent. [IMG][/IMG]
Old Jul 4, 2014 | 06:36 AM
Lost Again's Avatar
Degrees
Old Jul 4, 2014 | 07:27 AM
forward's Avatar
There are two measurements- Standard, then new, which are the second set if numbers in parentheses. If you're using new parts, use the numbers in parentheses for the alignment specs. If you're dealing with used parts, i.e. front end with 138k miles on it, use the first numbers.
snoopaloop986
Feb 19, 2014 11:56 PM
ca-rs
Jan 25, 2008 11:34 AM
