What size socket to get the battery terminal cables off?
Old Jul 3, 2014 | 09:37 AM
W95civicEXcoupe's Avatar
GDD's Resident Derp
Default What size socket to get the battery terminal cables off?
It is like 100 degrees or so outside, and I am chilling in the AC. I could be having my battery on my CTEK charger, checking its state of charge and condition (heat kills batteries.) I have a big huge 1/2" socket, baking outside in my truck. I would like to know what size socket I will need, to actually un-fasten the negative and positive battery cables. Then I will let it charge, overnight or so. Want my battery as nicely charged on the CTEK so it does not succumb to all this heat. Car is working properly but, its getting hot, and why tax the healthy charging system.
My question is what size socket (is the size in mm?) to buy to get those top-post connectors off.
Old Jul 3, 2014 | 09:38 AM
grumblemarc's Avatar
The Grumpiest
Default Re: What size socket to get the battery terminal cables off?
10mm
Old Jul 3, 2014 | 09:42 AM
HondaPartsHero's Avatar
Technical Hero
Factory is 10mm and a lot of aftermarket is 1/2" (13mm will work too)
Old Jul 3, 2014 | 10:25 AM
GDD's Resident Derp
^^ Thank you so much!!! I appreciate the information.
I guess we will now see if my battery cables are factory originals or not :D
Old Jul 3, 2014 | 02:51 PM
GDD's Resident Derp
^^ Welp. WEIRD! Negative terminal is 12mm, and Positive is 1/2 inch.
I have the battery on the CTEK now. Seems to either be perfectly healthy, or "surface charged." Wanted to get it on there... been nothing but HOT for a couple weeks, with constant use. I hear that kills batteries.........
Oh, and my battery has the "removable caps." Should I go messing with the water. Or just leave it alone. ? ..
Old Jul 3, 2014 | 02:52 PM
GDD's Resident Derp
Old Jul 4, 2014 | 12:24 PM
GDD's Resident Derp
^^^ Just an update: I did not mess with the "battery water" level, and simply re-installed it. All seems well.
lilboxx
Dec 10, 2012 04:10 PM
gpsports2k
Honda Civic (2001 - 2005)
Apr 10, 2008 07:03 PM
The-Kid
Dec 31, 2006 08:25 PM
eJ6DM
Jan 7, 2006 02:24 AM
DC2 to AP2
Audio / Security / Video
Jul 16, 2005 06:27 PM
