2000 Hatch b16 engine swap questions
Old Jul 2, 2014 | 03:41 AM
MagicJ_2000cx's Avatar
Default 2000 Hatch b16 engine swap questions
so i want to swap a b16 vtec in to my 2000 Honda civic cx but apparently there the b16a1 and the b16a2 which would let me pass emission because apparently one of them would no in my car i live in Ontario Canada any help would be greatly appreciated
Old Jul 2, 2014 | 04:00 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 2000 Hatch b16 engine swap questions
You can pass emsissions with either. You should type more clearly. Or just type the message after you pull over.
Old Jul 2, 2014 | 04:55 AM
okay but whats the difference between the A1 and A2 which would be easier(less wiring) to sawp in
Old Jul 2, 2014 | 07:38 AM
B serious's Avatar
Same amounts of wiring.
The A2 will have the misfire detection sensor (CKF).
You can either install a B16A2 oil pump and CKF onto the A1 or do the CKF trick (google that).
The A2 will also have an OBD2 distributor...but it will likely need rewiring anyway.
The A2 comes with OBD2 injectors.
You'll need some of the intake manifold sensors from the A2 as well as rerouting some lines into a single port.
You'll have to rewire the O2 sensor harnesses with either engine (extending wires).
It doesn't matter which longblock you use. The ECU doesn't know or care what longblock is in there. You attach the right sensors which send/recieve the right singnals and the ECU is happy.
The A2 happens to have the right sensors attached to it in the right spots already...so its an easier swap in that respect. With the A1, you'll need to buy a couple things and swap a few things around.
I also have no clue how your emissions testing actually works. An A1 would not easily pass inspection in CA simply because its older. In other places...IL, for example, as long as the USDM OBD2 ECU shows no CEL, you're good to roll.
You can find detailed answers on google or honda-tech or a million other places.
What is the A1 coming out of? Was it already in another OBD2 car?
OR......
You can use a EM1 engine harness, and B16A2 distributor, injectors, intake manifold, IAT, oil pump, and CKF. That makes for almost no wiring changes at all.
Everyone seems extremely scared of wiring.
Old Jul 2, 2014 | 07:47 AM
JuggerNaut-CTR's Avatar
Goodluck finding a b16a1. Thats the 150hp edm motor that is not anywhere around North America at all. Might as well throw that motor choice out the window. B16a2's are a dime a dozen and is a super easy straight forward swap.
Old Jul 2, 2014 | 08:13 AM
B serious's Avatar
JDM B16A's are easier to find than either. Plus you have the LSD trans option. They're all easy swaps. It just requires some reading.
Old Jul 2, 2014 | 03:23 PM
andoxviii's Avatar
As long as he is using the proper OBD2 ECU (not a chipped ECU with God-knows what kind of tune) and a proper catalytic converter, he will pass emissions here in Ontario. The emissions guys need to plug into a working OBD2 port to pass.
EDIT: I forgot to mention, there also cannot be any CELs present at the time of the test.
Old Jul 2, 2014 | 03:34 PM
01-0720's Avatar
if youre looking to pass emissions and have an easy install
get a b16a2 out of a 2000 civic si, sir in canada, and use the sir engine harness, distributor oil pump etc, no cel no install problems
duneracer69
May 12, 2008 06:24 PM
phillycx
13
Nov 21, 2003 07:31 AM
