Anyone with Spoon setups
Old Oct 30, 2002 | 09:21 PM
capcon83's Avatar
Default Anyone with Spoon setups
have spoon cams and CTR pistons have there car dynoed?
wanted to know if they highered there compresion how much power did they make
Old Oct 30, 2002 | 11:32 PM
STEALTHMODECOUPE's Avatar
Default Re: Anyone with Spoon setups (capcon83)
dont know to much about the CTR pistons but the spoon cams have just a little higher lift than the CTR ones..im getting a b18c soon and am going w/ spoon cams because not only are they higher lift cams but you dont have to change your valvetrain and they should pass emissions no prob..does anyone know of any other mild cams that will pass emissions and dont have to change your valvetrain??thanks
Old Oct 30, 2002 | 11:33 PM
Default Re: Anyone with Spoon setups (STEALTHMODECOUPE)
o BTW do a search..click on the archived topics and then type in spoon cams..youll find a ton of stuff including dyno sheets
Old Oct 30, 2002 | 11:36 PM
B2FiNiTY's Avatar
You want to go back to spoon?
I'll get back to once my friend finishes his car.
Old Oct 31, 2002 | 05:44 AM
sackdz's Avatar
Ask pinota
Old Oct 31, 2002 | 06:01 AM
rodimus's Avatar
skunk2 stage 1 cams.
Old Oct 31, 2002 | 09:27 AM
AJ PwR's Avatar
We have customer running B18C 11.1CR +B16A head with Spoon cams put out 189whp and if you run higher CR I will assume you can make up to close to 200whp.
Old Oct 31, 2002 | 09:45 AM
pinota's Avatar
Default Re: Anyone with Spoon setups (sackdz)
Ask pinota
I got spoon cams but they aren´t tuned yet. I don´t have adjustable cam gears.
I like them, of course they´re not the best cams in the world but i like mild cams.
I´m running only 11.5 CR, Wiseco 82.mm pistons. I´ll post results after dyno without and new cam gears on.
Old Oct 31, 2002 | 10:17 AM
EGtoR's Avatar
IF you want to run higher compression with the CTR piston, why bother with a mild cams like the Spoon one? Go with Toda B or C or JUN 3.
Old Oct 31, 2002 | 10:47 AM
RagingAngel's Avatar
Default Re: Anyone with Spoon setups (EGtoR)
because some people don't want to drop the extra $$ for the valvetrain to be done.... with the recent hubbub on snapping timing belts that's another extra cost involved when going with big cams.... what about injectors too? The list continues....
Old Oct 31, 2002 | 11:21 AM
EGtoR's Avatar
Default Re: Anyone with Spoon setups (RagingAngel)
That's true, but if you want to run Spoon cams, the JDM ITR piston with a thin headgasket should give you more than enough compression.
With the CTR piston on such a mild cams, one may run into some detenation problem if he don't have a good tuner.
Old Oct 31, 2002 | 11:07 PM
AJ PwR's Avatar
The thing is according to most of the dynoplot , you can see Spoon cams has a very useful power ranges for street to track.
Old Nov 1, 2002 | 12:24 AM
Default Re: Anyone with Spoon setups (AJ PwR)
i plan on going with spoon cams and heard they have really good mid range but hows there top end?? thanks
Old Nov 4, 2002 | 10:55 PM
capcon83's Avatar
Default Re: Anyone with Spoon setups (B2FiNiTY)
the jun 3 was my friends setup
i still have the spoon
made 180 whp
with only AEM cold air V-AFC, comptech 4-2-1 header and spoon cams
stock ex
about to get ctr pistons put on and hytech header + ex in couple months (2)
Old Nov 4, 2002 | 10:57 PM
capcon83's Avatar
true thats why i got spoon
Old Nov 4, 2002 | 10:59 PM
hows there top end bro??
Old Nov 4, 2002 | 11:01 PM
AJ PwR's Avatar
Here a dynoplot of the Spoon cams. You can see the power ranges. https://honda-tech.com/zerothread?id=262022
[Modified by AJ PwR, 12:02 AM 11/5/2002]
Old Nov 4, 2002 | 11:03 PM
thanks much man
jdm ek ferio
26
Mar 10, 2006 07:59 PM
dElSleepiE
May 9, 2004 11:55 AM
p-boy
Apr 25, 2002 02:35 PM
