Hi, I Iz a car being built by SH!FT.
Old Jun 30, 2014 | 06:11 PM
sh!ft's Avatar
Who the fack changed my title?!
Default Hi, I Iz a car being built by SH!FT.
(donor head)
(donor block)
https://www.facebook.com/photo.php?v...ideo_processed
Old Jul 2, 2014 | 08:26 AM
ChaseIntegra's Avatar
Default Re: Hi, I Iz a car being built by SH!FT.
and then... where's the description?
Old Jul 2, 2014 | 09:06 AM
sh!ft's Avatar
pictures will be the description for this build
Old Jul 2, 2014 | 06:20 PM
sh!ft's Avatar
Old Jul 2, 2014 | 06:42 PM
jdmjunkieXL's Avatar
Custom pistons or shelf pistons? lsv or b20?
Old Jul 2, 2014 | 07:02 PM
sh!ft's Avatar
i wanna say they are shelf. but there was a job number on the side of the box so i have no idea.
lsv.......T
Old Jul 2, 2014 | 11:39 PM
sh!ft's Avatar
Old Jul 5, 2014 | 01:34 PM
Tubby 66's Avatar
What is the P to W clearance set to?? How much power?
Old Jul 5, 2014 | 01:47 PM
Brice.Hayden's Avatar
I'm sure he has no idea on power yet. It's not even assembled yet.
Old Jul 5, 2014 | 11:00 PM
sh!ft's Avatar
im personally shooting for 475-500(thats why i made a thread on gaping the rings) but im not sure on what the customer wants. im assuming the same because this is only the block ive shown you guys.
the customer is swinging by this week to pick up the head to have it pnp'd....
Old Jul 7, 2014 | 03:25 PM
Tubby 66's Avatar
Well P to W needs to be set BEFORE assembly. The block looks like it's already been to the machine shop. That's why I'm asking. Set piston to wall 1st THEN gap the rings. You have to have a power goal before assembly to obtain the respectable tolerances. The more power you make, the bigger your clearances need to be.
Anyway 500 hp?? .0035-.004 will probably suffice.
Old Jul 7, 2014 | 07:49 PM
sh!ft's Avatar
but i thought it would have to be remachined again if the p2w wasnt right?? im pretty sure that was already done but ill check tomorrow with my shop to make sure.
on the other hand the guys at arias said its ok to run .021(which it already was or grind up to .022 which i might do) on the top ring and 18-20 on the 2nd ring. and to have the oil ring facing up like a W instead of an M look.
Old Nov 10, 2014 | 06:34 PM
sh!ft's Avatar
fitbkeco
Mar 11, 2013 06:27 AM
Dellgary
Acura TSX
13
Feb 3, 2012 08:11 PM
sittin on GOLD
Mar 21, 2006 07:57 PM
94si94cx
Mar 16, 2004 08:22 AM
